It is currently Wed Nov 04, 2026 12:35 pm
Post Posted: Mon Nov 07, 2011 8:58 am
so i have a 2,5 v6 gv it feels like the spark is breaking down on low rpm not sure how to test the coil pack indervidualy?
and any one know where to get some good priced new ones?
Post Posted: Mon Nov 07, 2011 11:45 am
get a spark plug and put the coil on it,make sure you earth out the plug on something on the motor, and also make sure you dont touch the sparky end :crazy: turn it over and you should see a nice blue spark if you used a new plug out of the box :helloo:
josh AKA Bazook
Post Posted: Wed Nov 09, 2011 10:48 am
will these fit?
is the price ok ?
was told they are $180 from suzuki
http://www.ebay.com.au/itm/NEW-IGNITION ... 5d2dc5a7b3
Post Posted: Wed Nov 09, 2011 10:51 am
oops i meant these ones
http://www.ebay.com.au/itm/NEW-IGNITION ... 27bf6c9eef
Post Posted: Wed Nov 09, 2011 10:56 am
they look the same
josh AKA Bazook
Post Posted: Wed Nov 09, 2011 11:20 am
Be careful with look the same - Suzuki used two different coil packs which are externally identical, the connector is the way to tell them apart - it can be 2- or 3-pin.
The 2-pin style were used on the early J18's, J20's & H20's, the cut off year was I believe '97 - the 3-pin style is used on the later vesions of the above mentioned engines, the J23's and the H25's & H27's.
The 3-pin coil packs have an ignitor transistor, the 2-pin coils packs are used with a separate ignitor module mounted on the firewall.
Post Posted: Wed Nov 09, 2011 11:24 am
my 97 build j20a runs the later 3 pin
Post Posted: Wed Nov 09, 2011 11:25 am
Same.
Post Posted: Wed Nov 09, 2011 12:20 pm
mine are 3 pin 99 model
so is this a good price?
im suprised some smart person hasnt made a replacment from another model thats cheaper and easier to obtain and hopefully more performance type
Post Posted: Wed Nov 09, 2011 12:29 pm
yeah good price, just the quality of the actual coil is unknown.... i guess you can be the Guinea Pig :wink:
suzukistore sell the just the probes for that sort of money
Users browsing this forum: No registered users and 358 guests
