It is currently Tue Oct 13, 2026 8:39 pm
Post Posted: Tue Jan 24, 2012 4:17 pm
I Have been warned not to get one because the clutch cable will snap. Has anyone tried one and had any problems?
Post Posted: Tue Jan 24, 2012 4:24 pm
i think i read on here on a old post there was a easy fix to this problem its been asked a few times b4 so have a search and see if u can find it if u cant some1 on here probs know what 1 im talking about
if u drive a loud toyota ute u drink rum
Vehicle: 03 Jimny
Post Posted: Tue Jan 24, 2012 5:05 pm
There's no need for a hd clutch in a Sierra
Standard one does just fine, the stress the hd clutch will put on the cable over a period will eventually snap your cable
Vehicle: Serria
Post Posted: Tue Jan 24, 2012 5:48 pm
I have had a hd exedy in mine for over 5 years. Have not snapped one yet.
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Tue Jan 24, 2012 5:54 pm
Wow.... yours must have a limited edition extra strength cable fitted :wink:
Post Posted: Tue Jan 24, 2012 6:54 pm
x2
Post Posted: Tue Jan 24, 2012 8:11 pm
yeah exedy hd in a sierra works well, other brands of hd dont
exedy hd in a vitara is the fail
Post Posted: Tue Jan 24, 2012 8:18 pm
i go for a custom clutch from npc that is heavy duty but the springs are adjusted so its not as hard on the pedal 8)
josh AKA Bazook
Post Posted: Tue Jan 24, 2012 9:02 pm
X2
Thats what i did.
Or just get a standard Excedy.
I went though 2 cables with the HD clutch and it was really heavy on the pedal. Plus you dont really need it. HD or standard it still wont last long if your riding the clutch all the time.
Vehicle: 1986 Sierra SJ50
Post Posted: Tue Jan 24, 2012 9:08 pm
HD Excedy feels the same as the original clutch. I;ve had one for two years and no dramas.
Post Posted: Tue Jan 24, 2012 9:31 pm
i used to have issues with the outer of the clutch cable pulling apart and squashing..
Vehicle: WT Tinny, NT lwb, 1L lwb
Post Posted: Tue Jan 24, 2012 10:09 pm
I just replaced the standard clutch on my sierra on the weekend after 4 years of solid abuse with the first 3 years running 31's on standard gearing.
The only reason I did this is because the pressure plate had dropped a couple of fingers but the clutch disk itself was as good as new.
I may be wrong here and feel free to correct me but a HD clutch seems like a solution to a problem that doesn't really exist.
JrZook - Mine only hangs 2.5".
 Profile WWW ICQ YIM
Vehicle: 2018 DMAX
Post Posted: Wed Jan 25, 2012 12:04 am
NPC special in mine, going strong with no cable issues.
Post Posted: Wed Jan 25, 2012 12:21 am
2nd zuk with excedy HD. No probs at all.
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Wed Jan 25, 2012 12:51 am
I've been running mine for 3 years with no problems at all.
Pedal isnt really much heavier then standard.
I think the HD clutches snapping cables is a bit of an internet myth.
We are amphibious
Post Posted: Wed Jan 25, 2012 1:26 am
awesome. thanks for all your help guys. what kind of price did you guys pay. just trying to get an idea of the average price i should be trying to find.
Post Posted: Wed Jan 25, 2012 1:27 am
Vehicle: 1985 Holden Drover
Post Posted: Wed Jan 25, 2012 5:52 am
I think i might be in need of a new clutch in the near future guys, reckon its worth the extra cash for the HD over a standard?
What would you be looking at paying for one?
1989 WT Sierra.
Post Posted: Wed Jan 25, 2012 6:15 am
Guess I'd just had too much to drink when I found my clutch not working due to a snapped cable.
Twice. :roll:
If you have gearing, and even an ounce of mechanical symapthy, there is no need for a HD clutch.
Post Posted: Wed Jan 25, 2012 6:33 am
X2.
In fact, I don't think you even need any mechanical sympathy if you have gearing.
Piggles has a 1.0 sized clutch, an ancient pressure plate, a flywheel that has never been machined, and a stock replacement exedy pressure plate.
I hate on it mercilessly, and it has given me zero problems (except she I filled it with mud - to be expected)
I didn't have the option of a stock suzuki clutch, but if I had a 1.3/1.6 that's what it would be getting - a factory suzuki clutch. Yes they are more expensive.
From what I have seen, these are the most tolerant to water/mud, resist heat the best, and give the best feel.
If you have crook gearing a heavy duty clutch is just a band aid for a gearing problem - like saying you need more power to compensate for big tyres.
Post Posted: Wed Jan 25, 2012 6:39 am
Twice. :roll:
In a sierra?
Ive i've had my clutch so full of mud it wouldn't disengage properly and was heavy as all hell and still wheeled all day like that.
It started to bend the fins on the pressure plate and had no effect on the cable.
To me thats a fair bit of load to have on the cable wheeling all day
I've never oiled or cleaned the cable and it still operates works well.
Maybe you've been unlucky with clutch cables or maybe i have a realy strong cable.
We are amphibious
Post Posted: Wed Jan 25, 2012 6:42 am
Twice. :roll:
In a sierra?
In a Sierra.
Maybe I had a bad run.... who knows. But it did make me realise that a HD clutch is just not needed. I've never had a standard clutch slip with proper gearing installed.
Users browsing this forum: No registered users and 238 guests
