It is currently Mon Sep 21, 2026 4:24 am
Vehicle: sierra
Post Posted: Wed Jul 03, 2013 4:21 pm
Hey guys I'm having trouble getting the crank sprocket off the crankshaft, I've stripped 2 bolts in it and need to replace it . I've got the bolt off no worries (which is meant to be the hardest part lol) but the sprocket seems wedged on the crank pretty tight. I tried a balancer puller and there wasn't enough clearance for it so I'm kinda stuck on what to try next. Is it just meant to slide off or do I need to get a pulley tool on it somehow? It's not the fanbelt pulley on the crank it's the sprocket that the timing belt goes on I was hoping I wouldn't need anymore special tools haha
Post Posted: Wed Jul 03, 2013 4:25 pm
you can bolt the fanbelt pulley back on and use that to wiggle it off, if you're lucky.
Post Posted: Wed Jul 03, 2013 6:00 pm
Lots of penetrating oil and leave it to soak. It should just slide off
Post Posted: Thu Jul 04, 2013 8:34 am
I used a bit of flat stock with two holes drilled in it to make a puller - put the center bolt back in part way for the flat stock to press against and then screw two of the four/five bolts in and tighten them down evenly - when you've pulled it as far as it will come, move the center bolt out and start over.
Post Posted: Thu Jul 04, 2013 3:31 pm
like atari said, put the pulley on and give it a wiggle or a light love tap. mine just fell off.
Users browsing this forum: No registered users and 198 guests
