Vehicle: sierra
Posted: Wed Jul 03, 2013 4:21 pm
Hey guys I'm having trouble getting the crank sprocket off the crankshaft, I've stripped 2 bolts in it and need to replace it . I've got the bolt off no worries (which is meant to be the hardest part lol) but the sprocket seems wedged on the crank pretty tight. I tried a balancer puller and there wasn't enough clearance for it so I'm kinda stuck on what to try next. Is it just meant to slide off or do I need to get a pulley tool on it somehow? It's not the fanbelt pulley on the crank it's the sprocket that the timing belt goes on I was hoping I wouldn't need anymore special tools haha
I used a bit of flat stock with two holes drilled in it to make a puller - put the center bolt back in part way for the flat stock to press against and then screw two of the four/five bolts in and tighten them down evenly - when you've pulled it as far as it will come, move the center bolt out and start over.
Users browsing this forum: Google [Bot] and 196 guests
