Hi, I have a 2005 Suzuki Jimny and for some reason my horn has just decided to not work. The fuse under that dash isnt blown. It is the one where the whole steering wheel centre is the button, not the two. Any one had this issue? Any one know whats wrong and how to fix it?
Joined: Sun Aug 10, 2014 12:14 pm Posts: 56 Location: Newcastle Nsw
Vehicle: 2002 Suzuki Grand Vitara wide
Posted: Mon Aug 25, 2014 12:12 pm
Locate the actual horn, probably behind the bumper or in the grill. Remove the spade connections from the horn. Either test the voltage at the connectors with a multimeter, whilst someone pushes the button. Or, supply 12v to the horn terminals and see if it makes a noise. If you get no noise from horn, then horn is stuffed. If you get no voltage when horn button is pressed, I would check the relay. Next most likely culprit.
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
Posted: Mon Aug 25, 2014 6:41 pm
My horn went ages ago. Replaced it with a spare from another vehicle. Its failed (well, its gone really quiet) to. Probably about time I hooked up my air horn.
Posted: Tue Aug 26, 2014 1:34 am
This is the one I have. Mounted under the wing of the bull bar. Wired with some heavy duty stuff. Can't remember the rating, but the vehicle wiring won't handle the current. Its about the dB output legal for a horn, in Australia.
For some reason I'm not being notified of any replies. But I have managed to fix it anyway. I tested the connectikns while someone pressed the button and there was power. I plugged a different horn on and it worked. So I got my original horn and there is a small hole on the back of it, i flooded it with wd40 and blew it out with compressed air. Works really well now. Also, Jezza, my horn has two connections? Mine doesnt earth directly to the car body.
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
Posted: Thu Aug 28, 2014 7:55 pm
Mine arrived yesterday, nowhere practical under my bonnet, I'll have to get a bit more creative with the location.
Posted: Thu Aug 28, 2014 7:58 pm
can you tuck it up in behind the front guard somewhere & protect it from the elements with the inner wheel arch plastics?
mines mounted low in my engine bay on the LHS under the rad overflow bottle... they have a breather port & mine ended up facing upwards so i just chucked on a small bit of heater hose that had a 90* bend on it to let it snorkel.
Posted: Fri Aug 29, 2014 7:19 am
Yeah that was my first thought, a bit worried about water, salt, sand, mud. I think I'll try your first suggestion, there's an opening where the factory air intake used to be which is directly behind the headlight. Hopefully that will let the db escape.
Users browsing this forum: No registered users and 40 guests
