It is currently Sun Jul 26, 2026 7:57 am
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Mon Aug 25, 2014 12:04 pm
Hi,
I have a 2005 Suzuki Jimny and for some reason my horn has just decided to not work. The fuse under that dash isnt blown. It is the one where the whole steering wheel centre is the button, not the two. Any one had this issue? Any one know whats wrong and how to fix it?
Thanks in advance,
Nick
Vehicle: 2002 Suzuki Grand Vitara wide
Post Posted: Mon Aug 25, 2014 12:12 pm
Locate the actual horn, probably behind the bumper or in the grill.
Remove the spade connections from the horn.
Either test the voltage at the connectors with a multimeter, whilst someone pushes the button. Or, supply 12v to the horn terminals and see if it makes a noise.
If you get no noise from horn, then horn is stuffed.
If you get no voltage when horn button is pressed, I would check the relay. Next most likely culprit.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Aug 25, 2014 1:02 pm
horn under bonnet next to release stearing you right in the face.
earths to body of car (only one connection)
meep meep
Post Posted: Mon Aug 25, 2014 6:41 pm
My horn went ages ago. Replaced it with a spare from another vehicle. Its failed (well, its gone really quiet) to. Probably about time I hooked up my air horn.
Post Posted: Mon Aug 25, 2014 7:34 pm
Air horn for the win
Post Posted: Mon Aug 25, 2014 7:40 pm
^^^ this
i has one of these vvvv pompoms
Post Posted: Mon Aug 25, 2014 8:08 pm
I've been meaning to get an air horn since buying the black Jimny. Just bought one of those, ^^^ thanks Gus.
Post Posted: Mon Aug 25, 2014 8:17 pm
they're literally the size of my hand & pack some punch.
vid:
:hey: Mr OP check to see if you haven't damaged the clock spring... pretty sure a few people on here have done it.
Post Posted: Tue Aug 26, 2014 1:34 am
This is the one I have. Mounted under the wing of the bull bar. Wired with some heavy duty stuff. Can't remember the rating, but the vehicle wiring won't handle the current. Its about the dB output legal for a horn, in Australia.
Vehicle: LWB Sierra & XL7
Post Posted: Tue Aug 26, 2014 12:10 pm
Easy fix !!
Extend arm outside of window, make your hand into a fist and raise your middle finger.
'92 Vitara & Camper trailer
Post Posted: Thu Aug 28, 2014 5:17 pm
For some reason I'm not being notified of any replies. But I have managed to fix it anyway. I tested the connectikns while someone pressed the button and there was power. I plugged a different horn on and it worked. So I got my original horn and there is a small hole on the back of it, i flooded it with wd40 and blew it out with compressed air. Works really well now. Also, Jezza, my horn has two connections? Mine doesnt earth directly to the car body.
Post Posted: Thu Aug 28, 2014 7:55 pm
Mine arrived yesterday, nowhere practical under my bonnet, I'll have to get a bit more creative with the location.
Post Posted: Thu Aug 28, 2014 7:58 pm
can you tuck it up in behind the front guard somewhere & protect it from the elements with the inner wheel arch plastics?
mines mounted low in my engine bay on the LHS under the rad overflow bottle... they have a breather port & mine ended up facing upwards so i just chucked on a small bit of heater hose that had a 90* bend on it to let it snorkel.
Post Posted: Thu Aug 28, 2014 8:34 pm
That's my favourite plan atm. Do you think it'll muffle it?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Aug 28, 2014 8:44 pm
130 something dBa. Probably not enough to stop people confusing the zook for a train
Weird mabie the earth wire is hidden on mine or something.
Post Posted: Thu Aug 28, 2014 9:03 pm
I want the full volume :D
Post Posted: Thu Aug 28, 2014 9:24 pm
what about in behind the bumper along side of where the big center opening is?
Post Posted: Fri Aug 29, 2014 7:19 am
Yeah that was my first thought, a bit worried about water, salt, sand, mud. I think I'll try your first suggestion, there's an opening where the factory air intake used to be which is directly behind the headlight. Hopefully that will let the db escape.
Vehicle: WT sierra, GU CRD
Post Posted: Fri Aug 29, 2014 8:55 am
Future reference.
Motorbike horns are the same as the zook ones.
If ya need one in a hurry bike shops would have them on hand.
I love ZD30. :)
Users browsing this forum: No registered users and 41 guests
