It is currently Fri Nov 13, 2026 3:43 pm
Post Posted: Tue Dec 22, 2009 3:30 am
got a 03 jimny not that long ago, looking at putting in diff locks, has anyone done this, can you give me links or suggestions please....can't seem to find too much out there, or i may be looking in the wrong places....
Post Posted: Tue Dec 22, 2009 3:36 am
air lockers are the way to go, i can install them for you if your looking to get them done
Post Posted: Tue Dec 22, 2009 3:45 am
was thinking rear only, what are your thoughts oozuk...
Post Posted: Tue Dec 22, 2009 5:11 am
I got 2 Phantom Grip lockers (LSD's really) from Suzisport for my Jimny. There is absolutely NO WAY that it would ever fit in the rear due to the 2 sets of pinion gears. The fronts fit only because we were able to grind down the side gears by a few mollimetres.
My only option if I wish to have a locker in the rear as I see it is an ARB air locker.
I actually think the LSD in the front and A/L in the back is a suitable mix because of course the front hubs re disengaged whilst on road and will not be constantly wearing as there is no way to lock and unlock the LSD itself. Whereas, the rear is a permanent drive diff, so a manual A/L is perfectly suited to this situation.
oozuk - What is your preference for rear locker in a 09 Jimny?
Vehicle: '96 LWB trayback
Post Posted: Tue Dec 22, 2009 5:34 am
In what way is your '09 jimny diff different to the earlier jimny years?
Reason being, I use a jimny diff centre in my '95 maruti/sierra - It was a bolt in swap.
Post Posted: Tue Dec 22, 2009 11:38 am
rear locker is always a good start just that alone will make a large difference to where your car will drive, buy an air locker, there much better fit and reliable when installed correctly, try to steer away from the ratchet lockers there more of a budget solution with the trade off being everyday driveability where the air locker behaves just like a factory diff when switched off, so driving on road is still great, also if you ever brake an air locker (which is unlikely in a jimny) every part of the locker is available as a replacement part so you can repair rather than replace
Post Posted: Tue Dec 22, 2009 5:06 pm
I have no idea how they are different. I am under the impresion they are the same.
The difference is between the front and rear. The rear has the extra set of gears and if these are removed to allow room, this would severely reduce the strength of the drive, and they would surely be shredded in a short time.
So, 1 LSD cost me $600. One Air Locker installed with tyre compressor will cost me $2,077. For an extra $600, I could have got dual air lockers. I suppose I could still go that way, but the front is installed already.
Post Posted: Wed Dec 23, 2009 12:28 am
rear is the same as sierra just different ratio, it's the front that differs as it's a high pinion diff centre
Post Posted: Wed Dec 23, 2009 12:30 am
please explain these extra set of gears that need removing that your talking about, i have no idea what your on about
Post Posted: Wed Dec 23, 2009 3:02 am
thanks for the input lads, will definately look into the air lockers. i assume arb is the place to start looking or is their another source i should try.
what is the ballpark figure i will be looking at, i'm assuming $1500 - $2000
Post Posted: Wed Dec 23, 2009 4:21 am
that's about on par for an air locker, let us know what they quote you for install.
Post Posted: Wed Dec 23, 2009 4:47 am
oozook. If I can get some photos tomorrow, I will post and explain.
I was told yesterday that there is someone on the AZ forum that works at UV4x4. If he is interested in offering a decent deal for supply only of the ARB tyre compressor and 1 Air locker for rear, I'd be interested.
Users browsing this forum: Google [Bot] and 85 guests
