It is currently Mon Oct 12, 2026 12:15 pm
Post Posted: Tue Apr 20, 2010 12:09 am
has any one put a leafy on a coily chassis?
Post Posted: Tue Apr 20, 2010 12:12 am
No...but i have heard it is a pretty easy swap
Post Posted: Tue Apr 20, 2010 12:19 am
well im going to do it just got too cut the front guards out i think
Post Posted: Tue Apr 20, 2010 1:16 am
not sure why the hell you would want to but should be possible
Post Posted: Tue Apr 20, 2010 1:29 am
because i rolled my coily and cant afford too buy a coily body
Post Posted: Tue Apr 20, 2010 1:32 am
got any pics? you might have a bit of trouble getting it rego'd. as far as i know the body has to be newer than the running gear if you are doing a body swap in QLD. Also do you have a body lined up? If not i might have one for you in a couple of weeks.
Post Posted: Tue Apr 20, 2010 1:49 am
bought a 94 model zook today full running gear and everything still going too
Post Posted: Tue Apr 20, 2010 1:50 am
oh righto, where did you roll yours? and why not just use the leafy if it still runs?
Post Posted: Tue Apr 20, 2010 1:57 am
qmag. because i want coils and i dont want too waste my car it cost too much i will never get my moneys worth out of it
Post Posted: Tue Apr 20, 2010 2:53 am
well check with the DOT before you do the body swap because you might run into issues with the year models. got any plans for the leafy rolling chassis?
Post Posted: Tue Apr 20, 2010 5:24 am
Zook_Fan is on to something, a leafy body wont have intrusion bars in its doors, and maybe other things :idea: So yeah I second his check with the Transport authority.
Clearance Hole Technology :P
Post Posted: Tue Apr 20, 2010 10:21 am
The dump pricks don't know shit from clay....I would be very surprised if they even payed that much attention to it. Tell them you rolled it and that the leafy is a replacement body, act stupid when or if they question it. If salvagable, put the coily front clip on the leafy to make it blend in a bit better.
Post Posted: Tue Apr 20, 2010 6:42 pm
im not 100% shore what too do yet i have a mate that has done the swap. so i can copy him. but i think i might just get the leafy registered so i have a car too get around in.
Post Posted: Tue Apr 20, 2010 8:12 pm
what Rusho said could be the case but its not a chance i would be willing to make without checking. I'm sure you could probably do it and get away with it but people also get away with rebirthig, doesn't mean its legal.
Post Posted: Tue Apr 20, 2010 8:47 pm
yea i will have to do something my coily is one of the best ones i have seen. cleanest interior and only 76000 K's bought it of a old couple that have owned it there sense new
Post Posted: Tue Apr 20, 2010 9:04 pm
well if all the drivetrain is that new it would be worth it to wack another body on top. if you do it you should look at grabbing anything coily specific that is salvagable though. if possible use the front clip, doors, door trims, dash, seats. that way it is going to look as much like the original as possible.
Post Posted: Wed Apr 21, 2010 2:19 am
yeah im going to do it proper or that stuff is good except the doors
Post Posted: Wed Apr 21, 2010 2:24 am
is the leafy the same colour as the coily? you'll need to swap your coily wiring harness in as well.
Post Posted: Wed Apr 21, 2010 2:54 am
nope. shit can i put a coily dash i n a leafy
Post Posted: Wed Apr 21, 2010 3:28 am
yes you can but its a bit of work. you may need to swap a few mounts from the coily into the leafy but you can get it in there. just don't try and put a roll cage in there.
Post Posted: Fri May 14, 2010 10:39 pm
how did you go with this?
Vehicle: 95 sj70 and 78 lj81
Post Posted: Fri Dec 03, 2010 7:13 am
Harvey, any updates with this????
Users browsing this forum: Google [Bot] and 269 guests
