It is currently Sun Jul 26, 2026 11:48 pm
Vehicle: 2012 Jimny, Locked both ends
Post Posted: Thu Apr 22, 2010 1:24 am
Hi all,
Today with my 24 hour old 1.3l sierra i was driving and all of a sudden, stopped. Thought i was spark, No it was sparking, Fuel? no plenty of fuel... coil??? nope, timing belt!!!! garrr
so anyway im a bit scared as i have been told that it often results in head damage, but the RAC bloke said it should be fine... so i dono would a 1.3L engine have any chance of head damage?
thanks in advance
Jordan
Post Posted: Thu Apr 22, 2010 1:29 am
Fit a new belt & enjoy, thay are a non interferance eng, so unless you were doing 8500 Rpm, you will be O K ! :P
Post Posted: Thu Apr 22, 2010 1:41 am
Sweet!!!! thats a load off my chest
Post Posted: Thu Apr 22, 2010 1:42 am
steknig wrote:
Fit a new belt & enjoy, thay are a non interferance eng, so unless you were doing 8500 Rpm, you will be O K ! P
As long as you don't have your head/block shaved down like mine you will be fine. there is a huge amount of room between the valves and piston tops.
Post Posted: Thu Apr 22, 2010 1:44 am
yeah as every one elce has said..
unless its a twin cam then its fucked.
Post Posted: Thu Apr 22, 2010 2:31 am
or...............
the cam belt could have snapped due to oil starvation in the head causing the cam to seize.
Post Posted: Thu Apr 22, 2010 2:44 am
joeblow wrote:
or...............
Been there, done that :cry:
Moral of the story is don't let people fix oil leeks on your engine with thread tape on bolts that go into oil channels!
Clearance Hole Technology :P
Post Posted: Thu Apr 22, 2010 2:56 am
If that was the case surly you would hear something, It wouldnt just stop and come to a nice rolling stop... i did find a washer inside the cover soo it is possible the last person who did it stuffed up and resulted in this, It was only one 40,000kms ago too!
Post Posted: Thu Apr 22, 2010 3:15 am
Distributor is driven off the cam..........
How did you have spark with a broken timing belt? :roll: 8O :?
Post Posted: Thu Apr 22, 2010 3:57 am
good call, Well i dono thought i saw spark, but i was sitting in the drivers seat looking through the window at the plug...
Post Posted: Thu Apr 22, 2010 5:33 am
HAHAHAHAHAHAHA
smoke and mirrors
Post Posted: Thu Apr 22, 2010 5:39 am
Let alone the fuel pump still pumping fuel???
Post Posted: Thu Apr 22, 2010 5:41 am
So the RAC guy must have unbolted the bonnet to check for spark? 8O
Vehicle: Clown Car..
Post Posted: Thu Apr 22, 2010 5:58 am
Highway-Star wrote:
joeblow wrote:
or...............
Yep vouch for that one to! not so much the thread tape, but certainly oil starvation causing the T-belt to snap.. Even happens on BRAND FREAKING NEW ONES!! HOW TO FIX... Make sure Head has OIL when cranking over, pour it in if ya have to..
Post Posted: Thu Apr 22, 2010 4:14 pm
screwdriver sparking on to block, but RAC bloke didnt check for spark, his a bit smarter then me i think :lol:
Post Posted: Thu Apr 22, 2010 5:07 pm
this story keeps changing more and more snapped t/belt but still spark and fuel this RAC bloke is tops easiest thing to do is pull the head of check valves piston tops if ok wind crank over to check bottem end is my thought no good slappin another t/belt on to just snap.
Vehicle: SJ80, SE416
Post Posted: Thu Apr 22, 2010 5:21 pm
Gotta be careful taking everything said by 5 minute roadside assistance people as being correct - an racq guy told me 2 weeks ago I had a broken timing belt - my stepfather and I took half the engine apart in my Honda before realising it was just a weak coil that was the problem.
Also, anyone had a timing belt skip a tooth or 2 in a zuk before - had a Toyota do that to me once...
Post Posted: Thu Apr 22, 2010 8:53 pm
Yep I have had my retaining spring on the timing belt tensioner fall down between the belt and gear and cause the timing belt to jump around a few teeth. Took me a while to figure out what was going on as it still ran surprisingly but not too well (as you might imagine).
As others have said if the fuel pump and distributor are still working the cam is still spinning and the timing belt is still working in some sort of fashion.
Post Posted: Fri Apr 23, 2010 12:33 am
fuel was getting sprayed into the carb when i pumped the accelerator, It was there may not have been enough to run the car, but it was there.
but timing belt is replaced, car is running great, and no head damage...
Post Posted: Fri Apr 23, 2010 12:36 am
oh and story isnt changing, as i said i checkd for spark and fuel, may not have
been correct but yeah RAC bloke only told me it was timing :wink:
so yeah pull the piss outa me, not the rac bloke, he was pretty good
Users browsing this forum: Google [Bot] and 409 guests
