Joined: Tue May 11, 2010 3:17 am Posts: 11 Location: NT
Posted: Fri Jul 16, 2010 2:43 am
Is it possible to fit a transfer case with a high ratio to a 2003 jimny with a m13a motor?The reason I ask,is I have just had a s/h transfer case fitted & while driving home I was doing 100km/h @ 4,000rpm according to my speedo/tacho,but a friend who was following says he had to do 120km/h to keep up.I am running 215/75x15 BFG AT's which would account for approx 5km/h.I won't mind if it is geard up a bit,as i've always thought it needed another gear.
I'm assuming that the apeedo drive on a Jimny is on the output of the T-Case like a Sierra so changing ratios won't make a difference to accuracy of the speedo reading...
Users browsing this forum: No registered users and 217 guests
