It is currently Tue Oct 27, 2026 10:35 pm
Post Posted: Sun Aug 01, 2010 12:57 pm
Have installed a jimny box and steering pump onto a sierra with a G13a.
jimnys run groove belts and G13a run v belts.
are there any accessory groove belt pullys available that are able to be bolted to the v belt pully on the crankshaft?
any suggestions would be grateful.
Post Posted: Sun Aug 01, 2010 4:00 pm
i think the way to do it is the change from v belts to the multi rib belts that way you can also run a falcon alternator as well
Post Posted: Sun Aug 01, 2010 8:26 pm
Swift with G13 eng in it.
Post Posted: Sun Aug 01, 2010 10:15 pm
If you are lucky yoy may find a pulley with single V for alt and waterpump, and a multi V for A/C/PS.
The sierra water pump cant fit the multigroove pulley, so you need to convert to a barina or baleno water pump.
These cant support the rad fan, so thermo fan is required.
And do a falcon alt while you are it, while posted above.
You may find a vit water pump with multigroove, then you can fit the clutch fan and vit fan shroud to the radiator.
If I am misinformed in any way, please let me know. As I haven't done this conversion as yet. But will be doing it to a G16B engine, that I will install soonish.
I have a cressida P/S box, 110A falcon Alt, need to go get a teardrop style P/S pump, and thermo fans.
Post Posted: Mon Aug 02, 2010 12:55 am
Just change the pulleys from the swift g13b multiv's. They easily bolt off.
The Baleno water pumps do support the engine fan, just use the sierra bolts and spacer.
Post Posted: Tue Aug 03, 2010 5:57 am
Thanks everyone for your help, I now have something to go on.
Vehicle: 85 SJ413
Post Posted: Tue Aug 03, 2010 10:48 am
The water pump pulley from an 8 valve Vitara will fit the Sierra water pump.
You can fit a Vitara crank pulley once you re-drill the bolt pattern from 5 holes to 4 holes.
For the alternator, just use a Vitara one, then you get a power upgrade as well.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Users browsing this forum: Google [Bot] and 433 guests
