| Author |
Message |
xedent
Joined: Mon Jun 15, 2009 11:30 pm Posts: 895 Location: Sunshine Coast, QLD
 Posted: Sat Aug 21, 2010 12:54 am |
Just went to the local wreckers and they have a G16bb there, i have taken some pictures but they are not very good, the sump is very very thin.
Anyone know what this is out of. Cheers.
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sat Aug 21, 2010 12:56 am |
Probably Baleno.
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Sat Aug 21, 2010 1:17 am |
Looks like something RWD.
_________________ Watch out or you'll get sued.
atari4x4
 Posted: Sat Aug 21, 2010 1:19 am |
looking at the sump, exhaust & engine mount, it would have to be out of a newish carry van or something similar
alien
 Posted: Sat Aug 21, 2010 1:22 am |
the carry didnt come in 1.6 did it?? i thought the only cars that used the g16 were baleno, swift and vitara?
Rhino
Joined: Tue Oct 13, 2009 10:30 pm Posts: 928 Location: Sunny Coast
Vehicle: 79 Lj80 stockman 94 swb Sierra
 Posted: Sat Aug 21, 2010 1:27 am |
atari4x4 wrote: looking at the sump, exhaust & engine mount, it would have to be out of a newish carry van or something similar
x2
stockman
Vehicle: 4wd
 Posted: Sat Aug 21, 2010 1:28 am |
The new vans are 1.6.
Are they side mount radiator?
atari4x4
 Posted: Sat Aug 21, 2010 1:32 am |
alien wrote: the carry didnt come in 1.6 did it?? i thought the only cars that used the g16 were baleno, swift and vitara?
the new APV thingo's come out with a g16 of some sort, when mounted it would be sitting on a 45* angle looking at that sump. the baleno's are almost vertical from memory.
xedent
 Posted: Sat Aug 21, 2010 1:47 am |
Ok, well what ever it is out of lol ill get some more pictures if the whole motor.
cheers.
_________________ My Maruti build, Click WWW
xedent
 Posted: Sat Aug 21, 2010 2:03 am |
I'm there now I made a mistake it's a g13bb out of a carry van anyone know if there's much work getting into Sierra ?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sat Aug 21, 2010 2:12 am |
G13 Sierra sump should bolt up.
Does it come with loom and ECU?
xedent
 Posted: Sat Aug 21, 2010 2:15 am |
Yes
xedent
 Posted: Sat Aug 21, 2010 2:22 am |
Will a carby 1.3 box mount to it ?
steak_knife
 Posted: Sat Aug 21, 2010 3:34 am |
APV!!!
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Sat Aug 21, 2010 3:53 am |
X2 APV.
Had a good look at one sitting on a pallet at Suziworld. They're weird.
Sure, everything could be swapped over to suit a Jimny/sierra/vitara, but geez, youd need a lot of stuff. (all manifolds, mounts, accessories, sump, pickup etc)
Steve
xedent
 Posted: Sat Aug 21, 2010 4:15 am |
That's what I thought, he only want $150 with loom and computer but.
Gwagensteve
 Posted: Sat Aug 21, 2010 4:22 am |
That's a good price if it's a sound motor.
Steve
BlueSuzy
 Posted: Sat Aug 21, 2010 4:28 am |
xedent wrote: That's what I thought, he only want $150 with loom and computer but.
Don't get it!
Wasnt the bolt pattern for the gearbox pissed?
Because the motor runs on a lean, the gearbox is vertical..
xedent
 Posted: Sat Aug 21, 2010 4:59 am |
Yep that's what I thought
Fatzook
 Posted: Sat Aug 21, 2010 6:29 am |
BlueSuzy wrote: xedent wrote: That's what I thought, he only want $150 with loom and computer but. Don't get it! Wasnt the bolt pattern for the gearbox pissed? Because the motor runs on a lean, the gearbox is vertical..
Yes, the bell housing pattern is clocked 45 degrees. But an adaptor would fix that.
xedent
 Posted: Sat Aug 21, 2010 6:46 am |
But if i put the engine to the correct position, wouldn't the throttle body and all the stuff be pissed ? i would really need to get all that from a jimny
steak_knife
 Posted: Sat Aug 21, 2010 7:01 am |
If you run it upright, it "should" bolt straight up to a vit box, sump & all other hang offer's will have to be changed.
Gwagensteve
 Posted: Sat Aug 21, 2010 7:16 am |
steak_knife wrote: If you run it upright, it "should" bolt straight up to a vit box, sump & all other hang offer's will have to be changed.
I believe the block will be the same as any other G16. as far as I could see when I was looking at it, it's only bolt ons that are different.
I assume the APV uses unique bellhousings to clock the gearbox in the correct orientation.
steak_knife
 Posted: Sat Aug 21, 2010 7:26 am |
Gwagensteve wrote: steak_knife wrote: If you run it upright, it "should" bolt straight up to a vit box, sump & all other hang offer's will have to be changed. I believe the block will be the same as any other G16. as far as I could see when I was looking at it, it's only bolt ons that are different. I assume the APV uses unique bellhousings to clock the gearbox in the correct orientation. Steve.
correct good Sir!!
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Sat Aug 21, 2010 7:29 am |
That exhaust manifold would make an excellent starting point for a budget turbo conversion
Buy it cause its really cheap. I would
_________________ Camels have nice toes
xedent
 Posted: Sat Aug 21, 2010 7:52 am |
It is a G13BB guys. Sorry
Gwagensteve
 Posted: Sat Aug 21, 2010 8:03 am |
It's still cheap if you can source the accessories and manifolds.
want33s
 Posted: Sat Aug 21, 2010 10:33 am |
I have a G16B inlet and fuel rail that I believe will bolt to a G13BB.
xedent
 Posted: Sat Aug 21, 2010 11:01 am |
I'm going to forget about this engine and find a G16B, thanks for the help guys.
