It is currently Fri Oct 16, 2026 10:48 am
Post Posted: Sat Aug 21, 2010 12:54 am
Just went to the local wreckers and they have a G16bb there, i have taken some pictures but they are not very good, the sump is very very thin.
Anyone know what this is out of. Cheers.
Post Posted: Sat Aug 21, 2010 12:56 am
Probably Baleno.
Vehicle: 4wd
Post Posted: Sat Aug 21, 2010 1:17 am
Looks like something RWD.
Watch out or you'll get sued.
Post Posted: Sat Aug 21, 2010 1:19 am
looking at the sump, exhaust & engine mount, it would have to be out of a newish carry van or something similar
Post Posted: Sat Aug 21, 2010 1:22 am
the carry didnt come in 1.6 did it?? i thought the only cars that used the g16 were baleno, swift and vitara?
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Sat Aug 21, 2010 1:27 am
x2
Vehicle: 4wd
Post Posted: Sat Aug 21, 2010 1:28 am
The new vans are 1.6.
Are they side mount radiator?
Post Posted: Sat Aug 21, 2010 1:32 am
the new APV thingo's come out with a g16 of some sort, when mounted it would be sitting on a 45* angle looking at that sump. the baleno's are almost vertical from memory.
Post Posted: Sat Aug 21, 2010 1:47 am
Ok, well what ever it is out of lol ill get some more pictures if the whole motor.
cheers.
My Maruti build, Click WWW
Post Posted: Sat Aug 21, 2010 2:03 am
I'm there now I made a mistake it's a g13bb out of a carry van anyone know if there's much work getting into Sierra ?
Post Posted: Sat Aug 21, 2010 2:12 am
G13 Sierra sump should bolt up.
Does it come with loom and ECU?
Post Posted: Sat Aug 21, 2010 2:15 am
Yes
Post Posted: Sat Aug 21, 2010 2:22 am
Will a carby 1.3 box mount to it ?
Post Posted: Sat Aug 21, 2010 3:34 am
APV!!! :P
Post Posted: Sat Aug 21, 2010 3:53 am
X2 APV.
Had a good look at one sitting on a pallet at Suziworld. They're weird.
Sure, everything could be swapped over to suit a Jimny/sierra/vitara, but geez, youd need a lot of stuff. (all manifolds, mounts, accessories, sump, pickup etc)
Steve
Post Posted: Sat Aug 21, 2010 4:15 am
That's what I thought, he only want $150 with loom and computer but.
Post Posted: Sat Aug 21, 2010 4:22 am
That's a good price if it's a sound motor.
Steve
Post Posted: Sat Aug 21, 2010 4:28 am
Don't get it!
Wasnt the bolt pattern for the gearbox pissed?
Because the motor runs on a lean, the gearbox is vertical..
Post Posted: Sat Aug 21, 2010 4:59 am
Yep that's what I thought
Post Posted: Sat Aug 21, 2010 6:29 am
Don't get it!
Yes, the bell housing pattern is clocked 45 degrees. But an adaptor would fix that. :wink:
Post Posted: Sat Aug 21, 2010 6:46 am
But if i put the engine to the correct position, wouldn't the throttle body and all the stuff be pissed ? i would really need to get all that from a jimny
Post Posted: Sat Aug 21, 2010 7:01 am
If you run it upright, it "should" bolt straight up to a vit box, sump & all other hang offer's will have to be changed.
Post Posted: Sat Aug 21, 2010 7:16 am
I believe the block will be the same as any other G16. as far as I could see when I was looking at it, it's only bolt ons that are different.
I assume the APV uses unique bellhousings to clock the gearbox in the correct orientation.
Post Posted: Sat Aug 21, 2010 7:26 am
correct good Sir!! :P
Vehicle: LJ20 LJ50
Post Posted: Sat Aug 21, 2010 7:29 am
That exhaust manifold would make an excellent starting point for a budget turbo conversion
Buy it cause its really cheap. I would
Camels have nice toes
Post Posted: Sat Aug 21, 2010 7:52 am
It is a G13BB guys. Sorry
Post Posted: Sat Aug 21, 2010 8:03 am
It's still cheap if you can source the accessories and manifolds.
Post Posted: Sat Aug 21, 2010 10:33 am
I have a G16B inlet and fuel rail that I believe will bolt to a G13BB.
Post Posted: Sat Aug 21, 2010 11:01 am
I'm going to forget about this engine and find a G16B, thanks for the help guys.
Users browsing this forum: No registered users and 258 guests
