It is currently Sun Nov 15, 2026 1:00 am
Post new topic Reply to topic  [ 116 posts ]  Go to page Previous  1, 2, 3, 4  Next
Vehicle: LJ20 LJ50
Post Posted: Tue Sep 07, 2010 8:28 am
Cool One huge lumpy top piston that takes two guys to kick start it and when it kicks back sends the two guys accross the room
Camels have nice toes
Post Posted: Tue Sep 07, 2010 8:32 am
Boring crankcase to suit big cylinder 8)
:woohoo: The cylinder fits
So does the head
Studs are too short now and they are an oddball size that is going to be fun to find
Post Posted: Tue Sep 07, 2010 8:37 am
Booker rod & tar should hold that head down.. :lol: :lol: 8O
Post Posted: Tue Sep 07, 2010 8:40 am
I have never seen booker rod in 7mm. I had enough trouble finding some nuts to get the studs out.
Vehicle: LJ20 LJ50
Post Posted: Tue Sep 07, 2010 8:44 am
1/4 is close enough
Post Posted: Tue Sep 07, 2010 8:49 am
TZAR wrote:
1/4 is close enough
The pitch is to coarse, they wouldn't go in more than half a turn.
I will probably just tap them out to 8mm
Post Posted: Tue Sep 07, 2010 8:50 am
mitre10 has some weirdo size lengths of metric.
Post Posted: Tue Sep 07, 2010 8:53 am
They need to be about 100mm long
Post Posted: Tue Sep 07, 2010 8:57 am
the lengths they have are 800 or so long. they are on the end of a isle near the work boots :wink: just get singie to pinch a heap for ya :lol:
Post Posted: Tue Sep 07, 2010 11:38 am
haha this thing is gunna be 8)
Post Posted: Wed Sep 08, 2010 1:40 pm
Just ordered a stroker crank and a set of carbon fibre reeds.
Out to 90cc now. 8)
Post Posted: Wed Sep 08, 2010 1:58 pm
one of my mates has a chinese KYMCO CVT scooter, that's got a big bore kit & head, larger carby, expansion chamber exhaust & different weights & other stuff done to the CV Transmission... it absolutely flys, it struggled to get past 50kph originally & that was with the speed limiter bypassed.
Post Posted: Wed Sep 08, 2010 8:41 pm
did something shit on the head?
Vehicle: LJ80
Post Posted: Wed Sep 08, 2010 8:59 pm
hmm
i just had someone behind me say "awsome"
i wonder where he picked that up from.
Post Posted: Wed Sep 08, 2010 9:03 pm
corrosion, it was sitting in the weather at the scrap yard.
a quick blow over with the bead blaster will make it pretty again
Post Posted: Wed Sep 08, 2010 9:13 pm
don't forget ya camera for the AZ science experiment. :wink:
Post Posted: Wed Sep 08, 2010 9:24 pm
i can't find it, the mrs has gone mad with cleaning again
it has been put in a safe place, she just can't remember where :x
Post Posted: Fri Sep 10, 2010 6:53 am
is it going yet?
Post Posted: Fri Sep 10, 2010 10:09 am
is it going yet?
Bloody slow postage from overseas somewhere. You think I would have my stuff after a day or 2.
I am waiting for the crank now and can't even do the porting without it. :x
Post Posted: Fri Sep 10, 2010 10:39 am
I recon you should just tec screew it on and zip tie it back together.
Post Posted: Fri Sep 10, 2010 11:50 am
fukin builders :?
Post Posted: Fri Sep 10, 2010 12:21 pm
ball wrote:
fukin builders :?
Shep does it and it works for him so it should work for you too :P
Post Posted: Fri Sep 10, 2010 12:36 pm
fuck no joe. dave is the roughest fella in the world. plus he is a kiwi. :wink:
Post Posted: Fri Sep 10, 2010 10:05 pm
well i'm a plumber so i say silicone and duct tape should sort it out
Post Posted: Fri Sep 10, 2010 10:15 pm
steady on mate, this is the NT and we don't need to over engineer stuff for rego.
Post Posted: Sat Sep 11, 2010 1:24 am
this thing should be pretty cool finished 8)
aerenandmel off here has a z50 he used to ride to work and the shops with a 125 thumpstar motor in it :lol: geared up a bit its a weapon
Post Posted: Sat Sep 11, 2010 1:30 am
and im a boily, hammer the thing on and weld it together with wet GP rodz!
Post Posted: Tue Sep 14, 2010 7:43 am
dont mention that.. some one coff coff ball will get angry
i actualy had a thought the other day...
since the cvt trans explode regulary.
whats stopping u geting a thumpser box (yep u hate them but hear me out)
and a 125 bore carbi head etc off 125cc dirt bike, something with the same stroke surely some one like you can match that up..
if you get a good lyfin box it will take the power easy, u will then have a clutch and a 4speed box?
just a idea
Post Posted: Tue Sep 14, 2010 7:46 am
Infact...
Lifin 125cc has a bore/stroke 54mmx55
Rm125cc has bore/stroke of 54.0 mm x 54.4 mm
i know rm is water cooled But surely there is something that will be a easy fit
Post Posted: Tue Sep 14, 2010 8:48 am
just a idea
The bottom end in a 4 stroke bike engine is all wrong for a performance 2 stroke. You need to try and keep the crankcase volume small to help scavenge the fuel air mix up the ports into the combustion chamber. 4 strokes tend to have quite a large crankcase volume.
Go and have a look at some you tube videos of hotted up european scooters. They would destroy a 125 thumpstar.
The variable speed drives and the clutches are all tunable and parts are readily available.
Users browsing this forum: No registered users and 7 guests
