It is currently Wed Nov 04, 2026 10:51 am
Post new topic Reply to topic  [ 823 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 28  Next
Post Posted: Thu Nov 19, 2009 1:21 pm
i towed an XR8 shitbox falcon and on the same day, a forklift.
Post Posted: Fri Nov 20, 2009 1:15 am
joseph wrote:
steknig wrote:
joseph wrote:
steknig wrote:
I towed a zook with my zook :roll:
Ive been waiting for ya to post that pic up :rofl:
What's so funny? :? try doing that with a moped!! :roll:
Its funny cause your the post whore and i knew you would post up that pic :wink:
You have a good point there!! :P
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Fri Nov 20, 2009 2:24 am
wat the hell was a fork lift doing out there??
Post Posted: Fri Nov 20, 2009 2:28 am
Lifting a fork silly!! :roll: :roll:
Post Posted: Fri Nov 20, 2009 2:54 am
Chop wrote:
Air-con or missing window? :thefinger:
chop
both 8) :finger:
Go Hard, Trailer Home
Post Posted: Fri Nov 20, 2009 1:35 pm
ball was testing the new difflock. :wink:
Post Posted: Sat Nov 21, 2009 5:41 am
Much to the amusement of the local kids I use my LJ50V to move my boat around the yard.
Post Posted: Sat Nov 21, 2009 5:45 am
[quote="2stroker"]Much to the amusement of the local kids I use my LJ50V to move my boat around the yard.
:shocked: nice LJ
Post Posted: Sat Nov 21, 2009 5:53 am
Thanks Joseph, if you like the outside you will love the inside, original KM's, unrestorded
Post Posted: Sat Nov 21, 2009 5:58 am
8O lucky prick.............show off :thefinger:
Post Posted: Sat Nov 21, 2009 6:00 pm
I'm guessing the LJ doesn't find it amussing 8O
Post Posted: Sat Nov 21, 2009 9:38 pm
Very nice LJ - Jealous. I've definitely got to drop by and check it out
Post Posted: Mon Oct 11, 2010 6:56 pm
Will be building a trailer percificaly to tow behind the LWB Sierra soon as the 6x4 box trailer i have atm is very heavy with long drawbar on 16" 6 studs. Will serve dual duty as general box trailer for firewood etc, and hopefully for camping gear with a fold out tent at a later date.
Obviously weight is an issue, so what have you guys built yours on? Was thinking 5'x3' on a 40x40x 2 or 2.5 frame with 50x50 RHS drawbar, same track as the Sierra running std 15x5.5 Vit or Maruti rims (already have both these) on 215R15 AT tyres, with shackled springs and maybe shocks. I want it to be strong enough to take constant dirt road use, but still light enough for the 1.3 Sierra to tow around.
Also, what hitches are you running ofroad. The std 50mm ball obviously has its limitations.
Post Posted: Mon Oct 11, 2010 7:24 pm
Im tossing around the trailer idea, if I do, it will be ally.
Light as, tuff enuf, alls well.
Post Posted: Mon Oct 11, 2010 7:49 pm
Yeah, thought about alloy but seen to many alloy truck bodies develop fatigue cracking over rough roads. Steel is easier for me to build too.
Post Posted: Mon Oct 11, 2010 8:09 pm
I understand the ease of manufacture, the fatigue bit, you cannot really compare a high load very stiff suspension like that found on a truck with a trailer built for a suzi.
Vehicle: '92 Sierra
Post Posted: Mon Oct 11, 2010 8:34 pm
I plan on using an alloy ute tray for the base of mine. As for the hitch check out Christover's camper trailer build http://www.auszookers.com/index.php?nam ... ht=trailer
I'm not sure if he detailed it much here but back in the day on outerlimits he detailed the offroad hitch he used. It was a greaseable ebay item I think that had really good range of motion.
Post Posted: Mon Oct 11, 2010 8:38 pm
This is the only picture I have of mine at the moment, but its pretty much exactly what you described.
40x40 frame, 1.6mm sides to 450 depth, sierra width on standar rims, 50x75 drawbar, 5'x3.5' and 175kg total weight inc tyres.
Tows great and carries way more than it legally should. :oops:
Post Posted: Mon Oct 11, 2010 9:30 pm
That looks about it Fatzook
Post Posted: Mon Oct 11, 2010 10:35 pm
You could look at Zukenutter's. Pure genius.
Mitch.
Mitch.
Vehicle: '92 Sierra
Post Posted: Mon Oct 11, 2010 10:54 pm
Are you boys using f100 hubs to get the right bolt pattern?
Post Posted: Mon Oct 11, 2010 11:04 pm
Yep.
Vehicle: '92 Sierra
Post Posted: Mon Oct 11, 2010 11:31 pm
Yep.
Cheers.
Vehicle: 93 Sierra
Post Posted: Tue Oct 12, 2010 1:26 am
Need to stick mine on F100 hubs and stock Zook rims yet ... currently on 14" Ford rims.
Think carefully about which way you want the rear to open and the clamshell top to flip. Mine is designed so I can pull off to the side of the road and set up if need be - the camber on the road keeps the rear swing gate open at 90 degrees (hits a chock at that point) and the clamshell also opens away from the road. We get up from the non-cantilever end using the mudguard brace and mudguard as steps - can store our shoes on the mudguard too that way :)
Heaps more pics/info if you want them. Original specs on trailer:
75x50x2.5 RHS drawbar with 50x50x3 EA chassis
2.1mm checkerplate floor (smooth side up)
1.6mm sides, 450 high
4 leaf slipper springs, spring over axle
14" Ford rims + tyres (incl spare), second hand
Jockey wheel
Lockable swing door rear and lockable drop-down front tailgate
All metal zincaneal treated with gloss black paint over
Total weight 220kg
Post Posted: Tue Oct 12, 2010 1:42 am
Moph
Good thinking with the tailgate. Was half thinking about trying to make it both swing out and be able to swing down as well, depending on use.
Do you find that you use the front tailgate as well?
Vehicle: 93 Sierra
Post Posted: Tue Oct 12, 2010 1:57 am
Not a lot at the moment. The whole top swings up and away if I want access to the inside - generally get gear out from under that way before setting up the tent and don't need to get in again until we're packing up. Haven't stayed in one place for long yet though so can imagine using the front tailgate in that case. It's useful having the option though - moved a 3 seat lounge + 2 recliners in one trip with the front gate down :D
Need to fit some jerry can holders to mine though to get weight back over the axle. This is what it looked like when we first left Perth ... took all the arch out of the 2" OME rears!!! Had to get some +50mm spring hangers made up in Exmouth to get the rear off the bumpstops :oops: :D
Post Posted: Tue Oct 12, 2010 4:40 am
Here's mine its 5x3 1/2
Im building another one next year that will be lighter, stronger and more suited to long hauls offroad
Post Posted: Tue Oct 12, 2010 7:01 am
or you could build your own custom sierra trailer.
Post Posted: Tue Oct 12, 2010 7:11 am
I remembered where my trailer pics were :)
5 x 4, made from standard light duty box trailer stuff, but I doubt I will be doing anything hardcore towing a trailer so would rather save the weight (tag says its 150kg)
One day i'll stick a rooftop tent on it but I rarely use it cause a swag is easier so wont be for a while.
Something I had been thinking about that would be good is one of them roofrack mounted awnings on a pivot that lays over on the opposite side of the trailer, so it tilts up to a decent height and you can roll it out as an awning for the tent, or out the rear
Post Posted: Tue Oct 12, 2010 7:28 am
Hey Joe, when you build your new one I'll buy that one! :D
I want my old sig back :(
Users browsing this forum: No registered users and 9 guests
