It is currently Mon Jul 27, 2026 4:04 am
Post Posted: Tue Oct 26, 2010 3:22 am
Ok so I'm replacing my rear bearings and seals.
Just need to know something.
Reading through this thread and he says watch out for small spacer washer, between brake plate and bearing.
http://auszookers.com/index.php?name=Ne ... cle&sid=17
So are the bearings in my pic like a closed bearing or is that my washer in the wrong spot. Cant see any other washer? Unless its tucked in the other side of the bearing?
Cheers for the help
Post Posted: Tue Oct 26, 2010 3:23 am
As Liz pointed out in this thread also http://auszookers.com/index.php?name=Fo ... ic&t=15938
The problem is no boobs :P
I want my old sig back :(
Post Posted: Tue Oct 26, 2010 3:30 am
toeragz what you have there is right. just replace the same way and you will be laughing.
Post Posted: Tue Oct 26, 2010 3:31 am
hay ben, why dont you fuck off for a bit? do ya need to be a tosser in every thread ya open?
Post Posted: Tue Oct 26, 2010 3:34 am
Ok problem solved
Post Posted: Tue Oct 26, 2010 3:39 am
Fuck shep whats crawled up your ass...
Nothing wrong with a bit of humour every now and again...
Post Posted: Tue Oct 26, 2010 3:43 am
Not when people are asking for help you douch.
yeah thats right. make suer u have the seal point outwoods, mine was backwoods (prev owner) and caused a MASIVE bearing fail!
Post Posted: Tue Oct 26, 2010 3:46 am
Sorry guys, I didn't realise that you had to be a miserable prick when someone wants some help....
Post Posted: Tue Oct 26, 2010 3:52 am
nah but just helping them would help. especily when its a simple question thats easy to ask.
Post Posted: Tue Oct 26, 2010 7:18 am
:? Bleeder nipple's at the bottom??
That small spacer is on the n/t ( narrow track) sierra's, the w/t's have it built in..
Post Posted: Tue Oct 26, 2010 8:22 am
Bleeders where its meant to be :) just took the photo upside down
car is a n/t, could it be a w/t bearing?
Post Posted: Tue Oct 26, 2010 8:25 am
Can you get a pic between the backing plate & the bearing??
Post Posted: Tue Oct 26, 2010 7:09 pm
its a tight squeeze for my camera lol
Post Posted: Tue Oct 26, 2010 11:34 pm
That most definately is a WT bearing,
as long as the seperate spacer from the NT setup was removed (which it appears to have been done) you have no worries.
Just in future, always buy the WT bearings so you have the inbuilt spacer, or you will need to source a spacer seperately as it doesn't come with the kits.
weaves
Post Posted: Tue Oct 26, 2010 11:58 pm
alright so I better get some w/t bearings :)
glad I asked before I went and bought some n/t.
Thanks for the help guys
Post Posted: Wed Oct 27, 2010 6:21 am
:P & don't forget to put the backing plate on BEFORE you fit the bearing's..
:P Done that before.. :lol:
Post Posted: Wed Oct 27, 2010 8:33 am
yeh try not forget that one :lol:
cheers again fella's
Post Posted: Wed Oct 27, 2010 8:44 am
would there be any negative effects if the backing plate was modified so that the bearing could slide through the centre of it? so you don't have to remove the brakes to get the rear axle out
Post Posted: Wed Oct 27, 2010 8:48 am
yeah the backing plate holds it in , to stop it from sliding out whilst driving ..
yeah that makes sense, didn't think that through... :roll:
Vehicle: zook
Post Posted: Wed Oct 27, 2010 7:09 pm
X2
Freaked out that i was going to have to grind off a perfectly new bearing. I made a special tool that I could use in the press to "pull" the new bearing off.
Its a shame it doesn't fit when there is a backing plate on there, other wise that would be the best way to get them off. In this case tight is not nice.
I doubt I will the use the tool again. If any one gets too excited like I did and pushes the new bearing on without the plate, give me a bell. Ill send the tool. :wink:
Post Posted: Wed Oct 27, 2010 7:41 pm
1 litres can do this, the americans like to mod the backing plates and run the 1 litre axle retainers so this can be done
Post Posted: Wed Oct 27, 2010 7:46 pm
Lowrange sell them.. 8)
Post Posted: Thu Oct 28, 2010 7:05 am
another question guys
Is the w/t seal different to a n/t. Just that my bearing seems in pretty good shape and can't see any major problems with it.
Think its the seal thats causing the diff oil to leak.
Any pics on the forum of some seals or any info is greatly appreciated :D
Post Posted: Thu Oct 28, 2010 7:43 am
its usually the bearing gone that makes the seal leak , but unlike front wheel bearings where you can grab the top and bottom of the tyre and feel play , you usually wont feel this play on a rear bearing , but if you jack up the car , and put both hands under the tyre and lift the wheel you will usually feel up and down movement.
ohh and the seal is the same n/t and w/t..
Post Posted: Thu Oct 28, 2010 8:10 am
cheers mate
Users browsing this forum: No registered users and 390 guests
