It is currently Sat Oct 17, 2026 12:12 am
Post Posted: Sun Nov 28, 2010 9:02 am
Will Vitara centres (5.12 I think) Fit in 1L NT diffs? I want to lower my crawl ratio on a budget. Currently running 31's on stock 1L running gear, High range is liveable for now but I am not happy with low range.
Post Posted: Sun Nov 28, 2010 9:27 am
Short answer....... No.
The 1L diff housing is too small.
LJ stuff will fit though 8)
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Sun Nov 28, 2010 9:29 am
Pwnd
95 Sierra SJ70 TinTop
Sutho wrote:
Got the answer to the asked question
:roll:
Post Posted: Sun Nov 28, 2010 9:31 am
if high range is fine look at 4.16 transfer gears, high range (for you) wont change, low range will be a lot better though
Post Posted: Sun Nov 28, 2010 10:39 am
What about 1.3L housings? I have some of these to bolt up but they are 3.9 ratio centres and was told they wont bolt up easily to my NT.
When I buy T case gears I'm gonna get the 6.5's as I want to eventually run 33's or 35's down the track. Plus you can't get transfer gears for 1L transfers can you?
Post Posted: Sun Nov 28, 2010 11:15 am
Only the 1.0lt Sierras with the 4wd light, either the metal dash with the light near the keys, or the plastic dash with the light in the instrument cluster.
Post Posted: Sun Nov 28, 2010 11:34 am
Post Posted: Sun Nov 28, 2010 11:44 am
dono1 wrote:
Post Posted: Sun Nov 28, 2010 11:47 am
Yeah if they are 1.3 NT housings with the 3.9 centres, then they will bolt in. The pinion flanges may be different, and the brake lines might be different, but otherwise its a fairly straight forward swap. Oh and you will need the 1.3L U-bolts etc also.
Bare in mind that this will make your low and high range worse until you fit the new transfer or diff gears.
Post Posted: Sun Nov 28, 2010 11:53 am
Thanks Fatzook.
Mine has the little light near the keys.
Will all T case gears fit or do I have to get certain ones? I thought the gears only fit 1.3L T cases.
Sorry for bein such a pain in the AR$& but zooks are confusing! :? :? :? :?
It seems like hardly anything is interchangeable.
Post Posted: Sun Nov 28, 2010 12:11 pm
If your dash has a little '4WD' light that comes on when you select 4wd high or low, then all aftermarket gearsets should fit your case. :wink:
And don't worry about being a PITA. Jccck has that covered :lol:
Post Posted: Sun Nov 28, 2010 12:17 pm
Awesome!!!
So that makes the 1.3L T case I bought redundent :cry:
4 Sale 1 x 1.3L T case :P :wink:
Stuff the diff ratios bring on the rockhoppers :D :D
Thanks for the help.
Post Posted: Sun Nov 28, 2010 7:28 pm
dono1 wrote:
Awesome!!!
sell your 1.0 case and put gears in the 1.3 case :wink:
Post Posted: Mon Nov 29, 2010 8:38 am
dono1 wrote:
Awesome!!!
And there's 2 good reasons for that.
1. Your 1.0 case with gears will probably be worth more to re-sell than a stock 1.3 case.
2. The 4.16, 4.9 and 5.14 reduction gears ALL require that you re-use a gear from the 1.3's set of gears to make a complete set. The 6.5 gears replace all gears in the case, so the original can be either a 1.0 or 1.3 case.
Before you sell either case, fit the gears into the 1.3 case and change over your flanges/brake drum off your 1.0 case. That way, you will be certian your driveshafts will go straight back in. If you then fit the 1.3 flanges/drum to your old 1.0 case, that will again make your 1.0 case a little more valuable to a prospective 1.3 owning buyer.
Post Posted: Mon Nov 29, 2010 8:44 am
The only problem I can see is the 1L driveshafts are like toothpicks!! The 1.3 driveshafts are HUGE (by comparison).
Post Posted: Mon Nov 29, 2010 9:31 am
Very friggin strong tooth pick's tho..
Post Posted: Mon Nov 29, 2010 9:53 am
Are they stronger than 1.3 shafts?
Post Posted: Mon Nov 29, 2010 11:32 am
Bout the same-ish. The 1.3s are hollow tube which is lighter rotating weight and easier in the factory to balance.
I've NEVER seen anyone twist up any Suzuki driveshaft due to gearing torque alone, only damage is caused by bending/denting the tube, of which the tube is more susceptible than the cast/forged shafts. Your 1.0 shafts will be fine, providing the splines are still good (otherwise you'd have replaced them already).
Post Posted: Mon Nov 29, 2010 7:40 pm
Thats good to hear cause i get a bit more clearance from the toothpicks :D
Users browsing this forum: Google [Bot] and 190 guests
