It is currently Wed Sep 23, 2026 9:12 am
Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3
Post Posted: Thu Dec 30, 2010 7:39 am
Suzistore is closed till the 4th, did ya try Suzukishop?
Post Posted: Thu Dec 30, 2010 7:47 am
like i said - talk to my mate, he'll give you the stongest grade he has =)
Post Posted: Thu Dec 30, 2010 7:49 am
ok, i will. but without seeing it, will he be-able to tell me what i need? thats why i range suzistore, to try and find out if it a "special" bolt or if i can use anything.
yeh ill give them a call, its after 5 so ill try tomorrow.
cheers
Mitch
Post Posted: Thu Dec 30, 2010 8:13 am
he'll ask for length, dia and thread... thats why i thought if you can park in his carpark, take the bolt out and walk in with it, you're guaranteed to get the right one - and you can fit it before you leave =)
Post Posted: Thu Dec 30, 2010 8:19 am
yeah thats what i was expecting, but if i can find out those things b4 i go into the store then it would be even better.
its also kind of a two man job, as when u try and tighten/loosen the bolt it turns the shaft. so someone needs to hold the wheel so it doesnt turn.
thanks tho.
Post Posted: Thu Dec 30, 2010 8:20 am
Take the key out of the ing & the steering lock will activate, &, lock..
Post Posted: Thu Dec 30, 2010 8:21 am
ahah thats awesome, but it may stop in a bad possition and make it harder to get to. thanks tho, i hadnt thought about that.
Vehicle: I drive your mum
Post Posted: Thu Dec 30, 2010 8:57 am
Well stick the key in, turn the wheel and lock it again so its stops in a better position. Seriously 8O
Layto....
Vehicle: LJ20 LJ50
Post Posted: Thu Dec 30, 2010 9:47 am
thanks tho.
Take the bolt out and measure it. OR puts pics of it one here with a ruler ( good one with mm on it) next to it. If it has a 12/13 mm head normally is a M8 if it has a 10mm head its a M6 and if it has a 14/15/17 mm head normally is a M12. then you need thread pitch. thats the distance between each thred. M6 should be 1.0 M8 should be 1.25 and M12 should be 1.25 or could be 1.5 mm.
OR take some metyric bolts to super shit (cheap) and go to there bolt merchandiser diplay and try your spare bolts in the merchandiser and work out what they are. mark them so you can identify them later. Then go home and try bolts what you know are certain threads GENTLY in the hole and make sure they screw in BY HAND. When you find the right thread count and size go to bolt shop and buy one for $15.00 minimum charge OR see old mates mate and get one for free by doing it in the carpark
Camels have nice toes
Post Posted: Thu Dec 30, 2010 9:57 am
thanks tho.
thanks, all i need now is a rough length which is around 30mm. ill try get one of these from somewhere, what i could do is removed the bolt at the firewall and use that!
cheers :D
Mitch
Post Posted: Sat Jan 08, 2011 9:01 am
well ended up getting a new bolt so thats all sorted :D
all i have to do now is get the steering wheel back to being straight, was planning on just taking it off and refitting it straight. will this work? and will i have any issue with the indicator returners thing?(tabs that turn the indicator off) if those tabs are on the shaft, and i move the wheel so its straight, will the little tabs stay at the angle or are they on the wheel?
cheers
Mitch
Post Posted: Sat Jan 08, 2011 9:22 am
theyre separate to the steering column dude, just take it off, reposition and tighten it back up.
Post Posted: Sat Jan 08, 2011 9:29 am
oh awesome, sounds good. will have a go in the morning when its light
Post Posted: Tue May 17, 2011 9:34 am
So did you just take it off and re fit it straight?
My steering wheel is a about 15 degrees counter clockwise off straight. Nothing seems bent.
Assuming wheel alignment is off as it pulls left occasionally when braking. (Checked brakes and wheel bearings already)
Was yours the same?
Post Posted: Wed May 18, 2011 1:48 pm
ahaha neither, its still on the piss. i tried taking it off but failed, will have another go this w.e but i have actually gotten use to driving it like it is. yeah mine is on the 45 to the left....anti clockwise.
when my lift gets put in, ill be getting an alignment then.
Users browsing this forum: Bing [Bot] and 196 guests
