It is currently Sat Oct 10, 2026 1:42 pm
Post Posted: Sat Mar 05, 2011 5:13 am
Hey all - anyone know how to tell the difference between a 1.3 and a 1.6 starter motor? Mines shat it and i dont know which is the right replacement?
PICS:
??? hard to take a good pic in that space.
Post Posted: Sat Mar 05, 2011 5:19 am
Looks like a 1.3
Disclaimer: I don't have a clue what I'm talking about
Vehicle: Zookless
Post Posted: Sat Mar 05, 2011 5:29 am
x2.
Is it hard up against the block?
Take it out, if it's been ground down, then it's definitely a 1.3.
Post Posted: Sat Mar 05, 2011 5:44 am
Im at sea so cant help, I have both, sorry.
Just by the pics, im not sure, but it looks diff to the 1.3 I pulled and replaced not long ago, but then, pics are pretty hard to id on.
Post Posted: Sat Mar 05, 2011 6:24 am
ScrawnC wrote:
Looks like a 1.3
1.3..... :D
Post Posted: Sat Mar 05, 2011 6:26 am
Or a non reduction 1.6, either way it's the big bodied starter..
Post Posted: Sat Mar 05, 2011 6:57 am
Tats what got me, big body on the sucker.
Post Posted: Sat Mar 05, 2011 7:00 am
Looks like a 1.3 to me. Alien could you take a pic of yours when you take it out.
I need a pic of a ground down 1.3 to fit a 1.6.
Post Posted: Sat Mar 05, 2011 7:11 am
i'll see what i can do... im getting suzistore to fit my new one - i can't imagine the hassle of grinding it down and test fitting over and over. they have reduction ones on order and none in stock =(
Vehicle: 85 SJ413
Post Posted: Sat Mar 05, 2011 7:35 am
Thats a 1.3 starter.
Heres a pic of the two side by side. The 1.6 narrow body starter is on the right:
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Sat Mar 05, 2011 7:57 am
Thanks all =)
Post Posted: Sat Mar 05, 2011 7:59 am
brian has small ones that fit both 1.3 and 1.6 they sound a bit different when cranking tho
Post Posted: Sat Mar 05, 2011 8:03 am
he's out of stock on the smaller reduction style ones =( hoping they will come in tuesday in time for me to get one put in, as i like the idea of one that bolts in rather than one thats been ground like all hell to make fit =P
Post Posted: Sat Mar 05, 2011 8:17 am
ive got a spare one you can grind to use in the mean time if you need
Post Posted: Sat Mar 05, 2011 8:26 am
thanks man, but i'll just get sean to grind me a fresh one if they don't have the reduction one in time.... joys of a daily driver is it needs to start every morning, lunch and arvo on demand =) haha
this roll starting off the starter motor is super-gay, and bad for my ring gear if i hold the key too long =P
Post Posted: Sun Mar 06, 2011 11:12 am
Thanks BenT, would it be ok to use that picture to show other people on other sites how to tell the difference?I could reall use it to explain the differences i get asked that question uite a bit.
Thanks
--sky
Post Posted: Sun Mar 06, 2011 11:27 am
Have you had a look inside of it yet? mates 80 series just had mud stuck inside it and was arcing out. The thing had like 2 - 3 breathers on it. :|
helloo
Post Posted: Sun Mar 06, 2011 11:31 am
Thanks
--sky
Once its on the web its fair game. :lol:
Post Posted: Sun Mar 06, 2011 2:41 pm
not yet - but will do... i also have a spare solenoid thanks to crewsy, so will most likely replace that anyway, as it gets moisture in it in winter.
has anyone found a way to reliably seal them up?
Vehicle: 85 SJ413
Post Posted: Mon Mar 07, 2011 12:28 am
Thanks
--sky
Of course mate, especially if you tell them I make adaptor kits to go with them :)
BenT 1.6 adaptor kits
Ben
Post Posted: Tue Mar 08, 2011 5:57 am
How to grind a 1.3 starter to fit 1.6:
Step 1: Grind
Step 2: Grind some more
Step 3: Better grind it one more time
Step 4: Admire grinding skills
Step 5: Smooth it out a bit
Step 6: Rust protection
To fit:
Disconnect battery, Remove airbox, remove original starter, put new starter in, re-fit airbox, re-connect battery...
Post Posted: Tue Mar 08, 2011 7:14 am
MMmmmmmmm, belt frucker upera :P
Post Posted: Tue Mar 08, 2011 9:34 am
Thats my 3rd most favorite tool at Suzistore, only go through about 4 belts a year and ohhhh what a nice finish :D
Suzuki is my way of life.
Post Posted: Tue Mar 08, 2011 9:41 am
I have a lil air powered one, have use it to cut steel, much to the amazement of my boss.... :D
Post Posted: Tue Mar 08, 2011 7:17 pm
Thanks for the pics Alien. ( I was LTM21 whoops)
Thats what I thought you would have to do. Grind right along the body of it.
Any chance this goin into "Good Tech" simple but pics paint a thousand words.
SS
Post Posted: Wed Mar 09, 2011 8:59 am
You dont have to always grind along the whole starter. Sometimes you only need gring it a little, bolt it up and see if you can slide a piece of paper behind it without it getting caught.
In Aliens case having all the injection gear in the way it was easier to do the whole lot and be sure that the starter does not foul the block.
As a reference G16A blocks are not as bolky near the starter (but they crack blocks more comonly) G16B blocks require more grinding as suzuki added a little more alloy and webbing to the block to try rectify some of ther issues of cracking blocks
Vehicle: 1985 LWB sierra
Post Posted: Mon May 06, 2013 9:08 pm
Did you have any trouble with the teeth not lining up? I'm about to do this and my mate tryed twice but then he started it and just shredded the fly wheel. This happened twice with the fat Sierra starter and then he got a long body one and had no trouble (Carby job) any tip when fitting it?
Users browsing this forum: Google [Bot], miki_E and 106 guests
