It is currently Sat Sep 26, 2026 1:24 am
Vehicle: '95 lwb vitara
Post Posted: Fri Mar 11, 2011 4:03 am
Just after some shockies that do the job and provide plenty of droop :)
Let me know what's ya thoughts?
Post Posted: Fri Mar 11, 2011 4:12 am
I run a commodore shock, but can't remember which one... you will need to swap the sleeve over in the bottom bush.
Post Posted: Fri Mar 11, 2011 4:14 am
Was just on the phone with a bloke at Fulcrum, I mentioned Commodore shocks. getting a pair tomorrow for $95 :D Cheap as chips and within dimensions. :)
I'll keep the sleeves Atari, cheers.
Post Posted: Fri Mar 11, 2011 4:18 am
check out the good tech thread
Post Posted: Fri Mar 11, 2011 6:13 am
up at the local super shit... they have a regular stock and are all of 35-40 bucks each.
Vehicle: SJ50 hardtop!
Post Posted: Fri Mar 11, 2011 9:05 am
Are you chasing more flex?? Best bet is to undo ya current shocks and measure the exact lengths your after. Commodore shocks are apparently the goods though
Has anyone used commodore springs, or are they too short/soft/wrong size??
NT SJ50
Post Posted: Fri Mar 11, 2011 9:07 am
Also note that your probably going to need extended brake lines.
NT SJ50
Post Posted: Fri Mar 11, 2011 9:37 am
Rear one supplied with the calmini kit should be fine, the fronts will be borderline.
Post Posted: Fri Mar 11, 2011 9:38 am
no, yes, yes, yes :D
Post Posted: Fri Mar 11, 2011 9:53 am
Youve stated it as being a 2" calmini lift in other threads, which is it?
Post Posted: Fri Mar 11, 2011 9:54 am
Mmm, mines close with standard calming rears, thought it'd need to be longer to get full flex out of a commodore shock
NT SJ50
Post Posted: Mon Mar 21, 2011 10:14 am
Chop; The bloke I bought the Vit off said it was a 2" kit but it turns out to be a 3". :) Found out after I posted the 2" comment..
What do you guys run for front shocks? Do commy fronts fit? and do they give the extension needed for a 3" kit like the commy rears?
Cheers fellas and sorry about the late replies..
Post Posted: Mon Mar 21, 2011 10:20 am
no, commonwhores are only good for rear shocks... fonts need a Vitara strut, OME, Dobinson or Ironman all do around a 30mm extended strut
Post Posted: Mon Mar 21, 2011 10:21 am
Alright cheers Atari. ;)
Post Posted: Mon Mar 21, 2011 10:53 pm
I've just unbolted the rear brake lines from the chassis cross member, frees them up enough to cope with the GV TDog travel. Need to find something longer one day though.
Just got a call from Fulcrum, the brake guy is in today, so getting some extended braided lines in the front while it's in for camber/alignment Armsup
Users browsing this forum: No registered users and 119 guests
