It is currently Fri Oct 30, 2026 10:51 pm
Vehicle: G16b 83
Post Posted: Wed Mar 30, 2011 5:24 am
just done the baleno engine conversion does anyone know what dipstick to use
Post Posted: Wed Mar 30, 2011 5:27 am
im thinking the baleno one
Post Posted: Wed Mar 30, 2011 5:50 am
Haha. I'm thinking the sump has been modified so would show a different reading using the baleno one.
Vehicle: Daisy
Post Posted: Wed Mar 30, 2011 5:52 am
Whichever one shows full when you put it in and you have the correct amount of oil in the engine?
Post Posted: Wed Mar 30, 2011 5:58 am
Logic at it's best. Good work.
Vehicle: Daisy
Post Posted: Wed Mar 30, 2011 6:01 am
It only works IF he has one that reads right at the correct level.
IF you want to do it dodgy, fill the thing up and then mark the dipstick as full level, start it so it fills the filter (and therefore takes some out) and mark that as your low level? or just fill it up with one litre less and make that low oil level, then put the other litre in and make that high level?
OR because you've got a modified sump and now no longer know what it should hold, you have to wing the whole shebang!
Post Posted: Wed Mar 30, 2011 6:41 am
if your using sierra the sump you would be using the seirra dipstick
Vehicle: G16b 83
Post Posted: Wed Mar 30, 2011 6:52 am
why do engines have a full mark is it to stop the engine slapping in oil ???
Vehicle: G16b 83
Post Posted: Wed Mar 30, 2011 6:54 am
the sierra dipstick seams to be miles too short tho
Post Posted: Wed Mar 30, 2011 7:08 am
if it sits the same height in the block it will be correct as you are using the matching sump to the stick.
put 3.5lt of oil or what ever sierras take and see but it should be right
Post Posted: Wed Mar 30, 2011 9:41 am
to use a sierra stick you need to use the sierra tube
what sump and pickup did you use? if the oil pickup it the same height as in a baleno and the sump about the same depth use the baleno one
Post Posted: Wed Mar 30, 2011 10:21 pm
i have a baleno motor, with a sierra sump, modified to hold the crank angle sensor. i used the baleno dipstick and never had an issue
Vehicle: Zookless
Post Posted: Wed Mar 30, 2011 10:58 pm
Same here.
You can see the Baleno dipstick on the left, just next to the oil pickup tube.
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Wed Mar 30, 2011 11:27 pm
CairnsZook wrote:
Same here.
mine is the same
Users browsing this forum: No registered users and 419 guests
