It is currently Sat Oct 17, 2026 6:16 am
Post Posted: Wed Apr 13, 2011 8:16 am
where is the length difference between the swb and lwb, is it between the front wheels and the tc or the rear wheels and the tc?
thankyou
Post Posted: Wed Apr 13, 2011 8:24 am
Rear wheels and t'fer case. Not sure of the exact measurement though, somewhere around 300mm ish I think.
Post Posted: Wed Apr 13, 2011 8:32 am
cheers, so this means both front driveshafts are the same length and only the back one is longer correct?
from memory the swb is 2030 and lwb is 2375 so 345mm
Vehicle: MY2019 Jimny
Post Posted: Wed Apr 13, 2011 8:53 am
Yes.
Post Posted: Wed Apr 13, 2011 9:11 am
and w/t maruti/lwb is different length to n/t lwb by about 75mm ?
Post Posted: Wed Apr 13, 2011 9:15 am
thanks, im extending a swb to a lwb and want to keep it as close to production as possible to make engineering it easier
Post Posted: Wed Apr 13, 2011 9:20 am
see if you can get your hands an a LWB driveshaft and then build the whole wheelbase extension off that... makes finding spares easier for tailshafts/uni joints =)
I'd be inclined to base it on a maruti shaft too, as theyre easily obtained new from india rather than 2nd hand.
Post Posted: Wed Apr 13, 2011 10:39 am
if the maruti shaft is 75mm longer again then its no good.
i will probs just get mine extended and balanced. i really need a wheelbase of 2375-2400
Post Posted: Wed Apr 13, 2011 10:48 am
engineer wont care about 75mm if he's engineering it anyway, and if maruti are still making them at 75mm longer then it wont matter =)
what size tyre are you running though? you want to make sure your rampover and departure angles are still good.
Post Posted: Wed Apr 13, 2011 11:05 am
it needs to be 2400mm +- 25mm max cos of the cab i am fitting otherwise yeh it wouldnt b a problem.
32s.
do you know if the lower part of the chassis is extended or the rear upper part on the lwb?
thanks for your help
Vehicle: 95 Sierra Soft top
Post Posted: Wed Apr 13, 2011 11:11 am
Is that all it is 345mm ? Omg thats like a bees dick,
But I like your idea mate good luck with the project ;)
Post Posted: Wed Apr 13, 2011 12:42 pm
maruti shaft is shorter
Post Posted: Wed Apr 13, 2011 1:14 pm
I have a 83 LWB bare chassis in Melbourne, free if You come and get it.
I have other LWB bits that could help, for a small fee too.
I have a LWB rear tail shaft from a 1.0L sierra too
christover
Post Posted: Wed Apr 13, 2011 7:53 pm
Christover your a champ, where abouts are you im pretty keen on taking this off your hands.
Post Posted: Wed Apr 13, 2011 10:31 pm
Just saw ur pm. Cheers
Post Posted: Wed Apr 13, 2011 10:35 pm
armsup true story :lol:
Post Posted: Thu Apr 14, 2011 8:20 am
Thanks to christover I now have a lwb chassis and driveshaft to suit, very much appreciated.
Post Posted: Thu Apr 14, 2011 9:45 am
You're very welcome, glad to see it go to a good project.
Users browsing this forum: No registered users and 254 guests
