| Author |
Message |
Hawky4X4
Joined: Thu Jul 15, 2010 10:37 am Posts: 133 Location: Mandurah,WA
 Posted: Tue Apr 12, 2011 12:01 pm |
Hey monkey and smiffkid, thanks thats the size or close to that ill b lookin at then
smiffkid
Joined: Fri Aug 13, 2010 12:55 pm Posts: 3266 Location: perth wa
 Posted: Tue Apr 12, 2011 12:53 pm |
no worries
_________________ dodgy brothers mechanical
FHA57
Joined: Thu Dec 16, 2010 5:35 am Posts: 179 Location: sunshine coast
 Posted: Thu Apr 14, 2011 3:37 am |
can someone please tell the kid that if ur gunna go to a crazy offset he should learn how to tighten/change wheel bearings
Hawky4X4
 Posted: Thu Apr 14, 2011 4:24 am |
Ive just ordered some -13 offset rims, so its not heaps and hopefully wont do anything to the bearings?
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Apr 14, 2011 4:40 am |
7" or 8" rim?
_________________ mlm
smiffkid
 Posted: Thu Apr 14, 2011 12:12 pm |
im running 15x8 neg 13 and they seem to be alright, as long as your balance your tires proper then then should be fine,
wat tires did u order
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Thu Apr 14, 2011 12:16 pm |
smiffkid wrote: im running 15x8 neg 13 and they seem to be alright, as long as your balance your tires proper then then should be fine, wat tires did u order
i yours looks way deeper than -13
_________________ Tell my arse, he actually gives a crap!
smiffkid
 Posted: Thu Apr 14, 2011 12:19 pm |
na there only 13, wanted to get 25 but for 200 bucks i couldn complain,
next set will be with bigger offset and also a special device
Hawky4X4
 Posted: Thu Apr 14, 2011 2:00 pm |
It's a 7 inch rim, is that size ok? The tyre place said it would b
Not really sure on which tyres to get but the size is gona b 31x10.5R15
smiffkid
 Posted: Thu Apr 14, 2011 10:30 pm |
yea 7 inch rim is fine for 31s,
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Thu Apr 14, 2011 10:41 pm |
i run 15x7 -38mm on mine =)
i run speedy 15x7 -15 previous to that which were great as well.
the -38 just fit my 31x10.5s inside the 50mm rubber flaring i've added to my WT flares.
SierraDan
 Posted: Thu Apr 14, 2011 10:53 pm |
Man thatd be wide!
FHA57
 Posted: Thu Apr 14, 2011 10:58 pm |
Hawky4X4 wrote: Ive just ordered some -13 offset rims, so its not heaps and hopefully wont do anything to the bearings?
nah u should be fine with that
Hawky4X4
 Posted: Sat Apr 16, 2011 1:39 am |
I was supposed to pik my rims up yesterday. . . . . . . Wrong stud pattern!!!  WTF!? now i gota wait till monday the wankers. . . . . . .
SierraDan
 Posted: Sat Apr 16, 2011 1:51 am |
how did they stuff that up?
monley
 Posted: Sat Apr 16, 2011 4:52 am |
Were did you order them from?
alien
 Posted: Sat Apr 16, 2011 5:00 am |
SierraDan
 Posted: Sat Apr 16, 2011 5:33 am |
Doesn't look much wider than mine..I could be wrong
alien
 Posted: Sat Apr 16, 2011 5:39 am |
yeah 15x8 -23 gives you almost the equivalent of a 15x7 -38 cos youre essentially 12.7mm wider each side on my 7" rim, so your -23 + -12.7 = 35.7mm
SierraDan
 Posted: Sat Apr 16, 2011 5:47 am |
Yeah righto. Then I agree it's a good width, and with my 2" lift it handles like its on rails dunno about your lift.
alien
 Posted: Sat Apr 16, 2011 5:53 am |
yeah it rides great =) the -38 is a huge and noticeable improvement over the -15... i opted for 7" wide to hold the bead on better at lower psi as well as skinnying the sidewall a bit more.
Hawky4X4
 Posted: Sat Apr 16, 2011 6:15 am |
I orderd them through tyrepower mandurah, but it wasn't there stuff up it the guys who sent them got it wrong . . . . .
SierraDan
 Posted: Sat Apr 16, 2011 6:27 am |
alien wrote: yeah it rides great =) the -38 is a huge and noticeable improvement over the -15... i opted for 7" wide to hold the bead on better at lower psi as well as skinnying the sidewall a bit more.
I got the 8" cos it's the standard haha.
Hawky4X4
 Posted: Sat Apr 16, 2011 6:30 am |
