It is currently Thu Jul 30, 2026 5:59 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2
Post Posted: Tue Apr 12, 2011 12:01 pm
Hey monkey and smiffkid, thanks thats the size or close to that ill b lookin at then 8)
Post Posted: Tue Apr 12, 2011 12:53 pm
no worries
dodgy brothers mechanical
Post Posted: Thu Apr 14, 2011 3:37 am
can someone please tell the kid that if ur gunna go to a crazy offset he should learn how to tighten/change wheel bearings
Post Posted: Thu Apr 14, 2011 4:24 am
Ive just ordered some -13 offset rims, so its not heaps and hopefully wont do anything to the bearings?
Post Posted: Thu Apr 14, 2011 4:40 am
7" or 8" rim?
Post Posted: Thu Apr 14, 2011 12:12 pm
im running 15x8 neg 13 and they seem to be alright, as long as your balance your tires proper then then should be fine,
wat tires did u order
Post Posted: Thu Apr 14, 2011 12:16 pm
i yours looks way deeper than -13
Post Posted: Thu Apr 14, 2011 12:19 pm
na there only 13, wanted to get 25 but for 200 bucks i couldn complain,
next set will be with bigger offset and also a special device
Post Posted: Thu Apr 14, 2011 2:00 pm
It's a 7 inch rim, is that size ok? The tyre place said it would b :?
Not really sure on which tyres to get but the size is gona b 31x10.5R15
Post Posted: Thu Apr 14, 2011 10:30 pm
yea 7 inch rim is fine for 31s,
Post Posted: Thu Apr 14, 2011 10:41 pm
i run 15x7 -38mm on mine =)
i run speedy 15x7 -15 previous to that which were great as well.
the -38 just fit my 31x10.5s inside the 50mm rubber flaring i've added to my WT flares.
Post Posted: Thu Apr 14, 2011 10:53 pm
Man thatd be wide!
Post Posted: Thu Apr 14, 2011 10:58 pm
nah u should be fine with that
Post Posted: Sat Apr 16, 2011 1:39 am
I was supposed to pik my rims up yesterday. . . . . . . Wrong stud pattern!!! :evil: WTF!? now i gota wait till monday the wankers. . . . . . . :windowface:
Post Posted: Sat Apr 16, 2011 1:51 am
how did they stuff that up?
Post Posted: Sat Apr 16, 2011 4:52 am
Were did you order them from?
Post Posted: Sat Apr 16, 2011 5:00 am
its wide, but not too wide:
Post Posted: Sat Apr 16, 2011 5:33 am
Doesn't look much wider than mine..I could be wrong
Post Posted: Sat Apr 16, 2011 5:39 am
yeah 15x8 -23 gives you almost the equivalent of a 15x7 -38 cos youre essentially 12.7mm wider each side on my 7" rim, so your -23 + -12.7 = 35.7mm
Post Posted: Sat Apr 16, 2011 5:47 am
Yeah righto. Then I agree it's a good width, and with my 2" lift it handles like its on rails dunno about your lift.
Post Posted: Sat Apr 16, 2011 5:53 am
yeah it rides great =) the -38 is a huge and noticeable improvement over the -15... i opted for 7" wide to hold the bead on better at lower psi as well as skinnying the sidewall a bit more.
Post Posted: Sat Apr 16, 2011 6:15 am
I orderd them through tyrepower mandurah, but it wasn't there stuff up it the guys who sent them got it wrong . . . . .
Post Posted: Sat Apr 16, 2011 6:27 am
I got the 8" cos it's the standard haha.
Post Posted: Sat Apr 16, 2011 6:30 am
Users browsing this forum: Google [Bot] and 474 guests
