It is currently Thu Jul 30, 2026 12:06 am
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Wed May 18, 2011 6:43 am
Just found out my petroworks kit is on it's way from lowrange. So I've got a couple of quick questions to ask.
The fuel pump. I can just use my standard tank and rig up an external mounted high pressure pump. Now should just go buy a Bosch vl turbo pump or is there a cheaper better option??
The clutch. Everyone says hd clutches are bad luck. I'm keeping the 1.3 box. So I think I'll just run a well known STD clutch? Exedy?
Radiator. Aftermarket alluminium 1.3 or a vitara one??
Main rear seal. Are all the 1.6efi the same as I purchased a import one. If u find the engine number can I just rake that to Suzuki?? Is there any other seals I should purchase at the same time say sump seal??
Post Posted: Wed May 18, 2011 6:50 am
The fuel pump. I can just use my standard tank and rig up an external mounted high pressure pump. Now should just go buy a Bosch vl turbo pump or is there a cheaper better option?? Just a stcok VL external pump will do
The clutch. Everyone says hd clutches are bad luck. I'm keeping the 1.3 box. So I think I'll just run a well known STD clutch? Exedy? Mnay have had issues with the HD's for some reason, i run a excedy HD in mine with no issues what so ever, very light clutch pedal too!
Radiator. Aftermarket alluminium 1.3 or a vitara one?? A new stock 1.3 one will do the trick if you keep the vit viscous fan
Main rear seal. Are all the 1.6efi the same as I purchased a import one. If u find the engine number can I just rake that to Suzuki?? Is there any other seals I should purchase at the same time say sump seal?? Should be no difference, sump seal use ultragrey
Lil Foot!
Post Posted: Wed May 18, 2011 6:56 am
I think I'll just buy a genuine clutch cable and always keep my old one as a spare inboard if I go hd
Vehicle: Nissan
Post Posted: Wed May 18, 2011 7:37 am
i run the same with a thermo fan :D
Pearce-toff Racing
Post Posted: Wed May 18, 2011 10:00 am
If I run the standard Sierra tank my mate says I'll have to do a lift pump and surge tank?? Is this true??
Post Posted: Wed May 18, 2011 10:05 am
Use the vitara radiator with the fan shroud and viscous fan. It looks neater and it's designed for the 1.6L engine so no cooling problems.
Post Posted: Wed May 18, 2011 10:18 am
Ok so any answers to my pump questions??
Post Posted: Wed May 18, 2011 10:54 am
You dont need a lift pump or surge tank.
Vehicle: 2018 DMAX
Post Posted: Wed May 18, 2011 11:02 am
And im the same again, vl pump, hd clutch and stock radiator with a 10inch thermo.
Post Posted: Wed May 18, 2011 11:07 am
Sweet I'll order these parts now
Post Posted: Wed May 18, 2011 12:21 pm
What do you need to do in order for the efi to work? Much wiring required?
Every problem can be solved with a Ratchet.
Post Posted: Wed May 18, 2011 9:49 pm
The guy who I bought the engine off was an autosparky he modded the loom for me.
Vehicle: 91 WT 1.6EFI
Post Posted: Wed May 18, 2011 11:29 pm
lucky man, I'm not looking forward to this part
Post Posted: Thu May 19, 2011 1:03 am
There's a guy on eBay that does a loom exchange I think like 350 or something. U give him ur loom and he returns a modded one.
Post Posted: Thu May 19, 2011 2:09 am
just had a look $420 all up! thats a hefty sum but firing up first go is also very attractive. maybe I just need to jump into bed with an auto eleky :)
Vehicle: '92 Sierra
Post Posted: Thu May 19, 2011 2:30 am
Yeah that should chew up 3 minutes while you wait for the ebay loom to arrive. :lol:
Users browsing this forum: No registered users and 613 guests
