It is currently Thu Sep 24, 2026 2:54 pm
Post Posted: Mon May 09, 2011 1:38 am
My 99 GV has developed the transfer case slipping out of 4wd problem, so I was looking at my options to fix it.
- Replacment transfer case from a 01-05 GV
- Get the new gear installed in the existing transfer case.
Then I spotted this
http://cgi.ebay.com.au/Suzuki-Transfer- ... 3ef4958bdf
Is there a way of telling/finding out if this will fix the problem? Does this look like a decent kit for the money? Will a transfer case rebuild be beyond the capabilities of a very amateurish mechanic like me?
Post Posted: Mon May 09, 2011 7:28 am
I would definitely find out wheat the problem is, before I ordered anything.
Maybe someone with more vitara experience can chime in, and tell us what the common causes are on vit cases.
It could be as simple as a shifter bushing, if they even have them on the vit cases.
Post Posted: Mon May 09, 2011 9:11 am
http://auszookers.com/index.php?name=Fo ... high+range
:helloo:
Post Posted: Tue May 10, 2011 12:55 am
I'd read that thread and my problem sounds exactly the same, jumping out of 4wd H and funny clunk noise in low range so I assume its the same gear wear problem that the early GVs seem to have.
I just thought this rebuild kit may an alternative to the replacement gear or whole new transfer case.
Vehicle: 2004 SQ625 GV
Post Posted: Tue May 10, 2011 12:49 pm
That kit won't help. The newer GV's have different profile of teeth the stay engaged better. Ring Suzistore, last time I was in Sean had fitted a new set of gears to a gv and showed me the difference. Was around $1200 from memory but that was labour and everything.
Post Posted: Wed May 18, 2011 2:42 am
Will an XL7 transfer case fit a 2.5V6 GV?
Post Posted: Wed May 18, 2011 3:16 am
I think that the input and output splines are different
Post Posted: Wed May 18, 2011 4:46 am
Cool.
It seems the transfer cases are more than I was hoping. I've been quoted 1100 and 1500 from wreckers here in Perth, so it may work out cheaper to get the new gears put it.
Post Posted: Wed May 18, 2011 8:51 am
carlos83 wrote:
Cool.
I would get the gears done in your case as well. Then you know you have a fresh T/C. You can't be sure the one you buy from a wrecker is the right year aswell.
Post Posted: Thu May 19, 2011 7:14 am
I've found one in NSW for $500 plus another $100 shipping to Perth. How hard will it be to swap them over? Anyone done one?
Users browsing this forum: No registered users and 140 guests
