It is currently Sat Aug 01, 2026 5:19 pm
Post Posted: Sat Oct 10, 2009 11:18 pm
I just swapped my diffs under my 1993 SWB WT and my 1987 LWB WT and the tail shaft doesn't bolt up is this becuase they have a different pinnion yoke and are they interchangeable???
Any help would be greatly appreciated.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Sat Oct 10, 2009 11:54 pm
correct. WT and NT have different pinion flanges.
The easy way to fix this is to swap the transfer flanges, or swap the yokes on your tailshafts to suit, or swap 1/2 your tailshafts so the short end is NT and the long end is WT.
Don't pull the pinion flanges off and swap them - you'll screw up the pinion bearing preload and destroy the diffs.
Post Posted: Sun Oct 11, 2009 12:33 am
But if i know how to do it properly i can change them?
I have installed a locker into it so i know what i am doing is this possible?
Post Posted: Sun Oct 11, 2009 1:37 am
it is possible if you get a new crush tube and set the diff up from scratch. :wink: if you do you may as well get a new pinion bearing and seal as well.
Post Posted: Sun Oct 11, 2009 3:29 am
X2, good on ya shep. :wink:
Post Posted: Sun Oct 11, 2009 5:38 am
So it will fit? Just wanna make sure.
Post Posted: Sun Oct 11, 2009 12:39 pm
Yes, it will fit, but that's a whole lot of work to "fix" something that doesn't need fixing. If you are pulling your diffs apart anyway, go for your life, but why open up a diff when there's no need?
You didn't explain which way round you were swapping, but the larger WT flange is superior - it runs bigger bolts- so if your diffs have the large flange that's what I'd be keeping.
Post Posted: Thu Mar 10, 2011 10:02 am
How do you torque these up if i have the new crush tube etc do you have to take the center out or what ?
My Maruti build, Click WWW
Vehicle: Vitara
Post Posted: Fri Mar 11, 2011 6:58 am
I went from NT diff centerS(Small flange) in NT housing to the wt diff centers(big flange).. i just got some WT drive shafts and they fit like the NT ones..
Repping it, High Top style!
Post Posted: Fri Mar 11, 2011 9:08 pm
Lwb Wt flanges are Nt. Including jackshaft and transfer flanges.
Swb Wt flanges are all Wt.
Post Posted: Fri Mar 11, 2011 9:10 pm
but 1.3 lwb sierra's are nt flanges ;)
Post Posted: Fri Mar 11, 2011 9:48 pm
my LWB has wt diff flanges :wink: but only because it has wt diffs :lol:
my front tail shaft is all wt and my rear is half wt and half nt because i
wanted to keep the transfer handbrake.
Post Posted: Fri Mar 11, 2011 11:40 pm
All lwb are Nt flanges..
Vehicle: LJ20 LJ50
Post Posted: Sat Mar 12, 2011 4:07 am
what about maruti's? aren't they lwb with wt stuff under them in the later models????
Camels have nice toes
Post Posted: Mon May 23, 2011 3:13 am
Whats the easy way to tell if the flange you have is WT or NT?
The bolts are bigger in WT? But does the flange also measure larger??
Post Posted: Mon May 23, 2011 3:49 am
88.5 no deal
Lil Foot!
Post Posted: Mon May 23, 2011 4:11 am
You've been around zooks long enough to know that even suzuki doesn't follow their own rules :lol: :wink:
I've seen quite a few oddball zooks with parts from other models OEM fitted.
And 1L LWB are not the same flange as 1.3 LWB.
Users browsing this forum: Google [Bot] and 320 guests
