It is currently Sun Nov 01, 2026 11:45 am
Post Posted: Sat Apr 30, 2011 7:04 am
Post Posted: Sat Apr 30, 2011 7:40 am
is it a yanky kit??
Does it say why they want you to run inverted shock's??
Post Posted: Sat Apr 30, 2011 8:02 am
probably means to run them inboarded so they dont bottom out
Post Posted: Sat Apr 30, 2011 12:11 pm
Ye it is a yanky kit, doesn't say why but I've sent an email asking if they can explain why.
Definitely shows and means inverted.
Post Posted: Sat Apr 30, 2011 12:56 pm
What do you mean by inverted?
I know with the calmini kit the shocks have to be used upside down (to clear the diff) if that's what you are talking about
Post Posted: Sat Apr 30, 2011 10:02 pm
this is what mine look like inverted it doesnt mean upside down
Post Posted: Sat Apr 30, 2011 10:05 pm
Inverted means upside down.
Inboarded means you bring the top shock mound inward(closer together)
Post Posted: Sat Apr 30, 2011 10:31 pm
i see said the blind man
Post Posted: Sat Apr 30, 2011 11:49 pm
adjective
Turned over completely: capsized, overturned, upset, upside-down, upturned. See horizontal/vertical/change of position.
http://www.answers.com/topic/inverted
Vehicle: Vitara
Post Posted: Sat Apr 30, 2011 11:51 pm
do they have adjustment knobs? could they mean to install them facing outwards toward the springs like Mr Rocky instead of inwards like mine?
I've heard of people running the Ranchos upside down to avoid the diff crushing the shock housing without any dramas.
Ron
Repping it, High Top style!
Post Posted: Sun May 01, 2011 12:08 am
Rancho RS9000 shocks do not work upside down.
Many years ago 4WD1 (who called themselves something different then) recommended a fitment for my Gwagen - it was the same part number front and rear, with the fronts upside down. My spring maker was suspicious they wouldn't work so we bought one and dynoed it right way up and upside down. They didn't work upside down, for the reasons the OP posted. The valving goes totally whack.
For some reason, illiterate hilux owners started the whole "inverted" thing to describe rotating their shocks from inclined fore-aft to across the car like a sierra.
Post Posted: Sun May 01, 2011 12:26 am
Yes I know its Lux and I know its snake racing but inverted shocks can also refer to inboarding, dont know why but they do. Have heard it being used for Sierra as well :crazy:
http://store.snakeracing.com.au/~snaker ... 16092576c8
Vehicle: Vitara
Post Posted: Sun May 01, 2011 12:57 am
Ohh Thanks for that Steve! I was contemplating flipping them to avoind any future damage.. will leave them be now :)
Post Posted: Sun May 01, 2011 1:48 am
I have introverted my rear shocks, but I can't show you a pic as they're a little camera-shy.
Post Posted: Sun May 01, 2011 2:24 am
Will update with the reply I get from Calmini, as they definitely do not work at all upside down.
Just thought I'd post so other people running the twin tube design shocks know they are not getting any use from their shocks if they have been inverted.
Post Posted: Sun May 01, 2011 5:33 am
I cut my brake line bracket things off and moved the brake lines on top of the diff. shocks are loving it.(RS9000XL)
Post Posted: Sun May 01, 2011 5:35 am
Id say its just become common talk as people say "i inverted my shocks" and describe it as moving them inward. So everyone has picked it up and spread it. But in reality, theyre two very different things.
Post Posted: Sun May 01, 2011 11:41 am
would be interested in these pics if u have them dan? unless they're on your build thread
Post Posted: Sun May 29, 2011 6:35 am
Any word from Calmini yet ?
Post Posted: Tue Aug 23, 2011 10:22 am
i run my calmini shocks upside down and they still work.
Post Posted: Tue Aug 23, 2011 10:28 am
but in saying that how long did you drive around with no shocks :lol:
Post Posted: Tue Aug 23, 2011 10:40 am
dunno what you are talking about :oops:
no shocks was fine until i tried to tow my boat, they went back in fairly quickly then.
i actually didn't notice a difference in the way they work no matter which way they are mounted.
Post Posted: Tue Aug 23, 2011 10:46 am
I ran mine upside down too, and they worked but not very well.
Post Posted: Sun Sep 04, 2011 1:24 am
Will confirm this. Tested it last week. Running no shocks and upside down 9000XL's was the same. It was nice having the soft ride while driving but, hit the brakes, need to turn or hit a speed bump and it was horrible to drive.
And in the bush it made things very difficult to control with the constant bouncing around.
Users browsing this forum: Google [Bot] and 403 guests
