It is currently Thu Oct 01, 2026 5:38 pm
Post Posted: Tue May 31, 2011 9:04 am
Hayy people I have a 92 Sierra with 31s extended shackles and 2in lifted ome springs I am after a 2 in body lift where can I get some should I make them and what do I need to do it
Do I need to adjust steering arm or not
Post Posted: Tue May 31, 2011 9:06 am
Just buy one from Just Cruzin:
http://www.auszookers.com/index.php?nam ... ic&t=15518
You can't make one without a lathe - socket bolts have to be fabricated.
Post Posted: Tue May 31, 2011 9:10 am
Yea I am a panel beater and can get everything from work but not shaw if I should I am a bit lazy and I would just like to buy them and do the body lift at work will I need to make a steel spacer for the steering shaft
92sierra ht 33s 5in lift 2in zorst gti powered
Post Posted: Tue May 31, 2011 9:11 am
Not with the kit from the link above, has a new thicker rag joint in it..
Post Posted: Tue May 31, 2011 9:14 am
Ahh ok
I've installed HEAPS of sierra BL's (used to make them when I had access to a lathe) and never needed a steering spacer at 2" BL.
To clarify, Bennyzarb, you have to bore out and tap a thread into 16mm bolt creating a socket bolt. Just Cruzin's are very nicely made, and the cost of his kit is low enough that making the bolts yourself doesn't make any sense.
Post Posted: Tue May 31, 2011 9:30 am
Ahh ok I spoke to my local wrecker and they make body lifts for sierras and want $800 installed they said they make the blocks out of 50 mm steel and bend the shifter and put a longer steering shaft in out of an older Suzuki but the just cruzin one sounds better cause I get to keep $600 for some transfer gears :) what do youse think of this body lift they make?
Post Posted: Tue May 31, 2011 9:34 am
I'm not a fan of body lift, but his are top shelf, if I had to lift I'd use his...
Post Posted: Tue May 31, 2011 9:39 am
Ive used Just Cruzin's body lift kit and can say its top knotch
 Profile YIM
Ahh ok
Users browsing this forum: Google [Bot] and 121 guests
