It is currently Sat Oct 31, 2026 5:58 am
Vehicle: 75 Cruiser
Post Posted: Sat May 24, 2008 11:49 pm
just wondering, It's been suggested that the idle up switch could increase the idle, not for general use, but for use in comps. So as a stock standard set up, if you turn your lights on the idle will go the set idle speed eh? Like say 1500rpm? Might sound obvious, but just thinking it might be handy for comps, just turn ya lights on and we're powering on :D
Yeah i could just go try it tomorrow on my car, if i can find the damn keys, but anyway i thought i'd just post it here for general info.
here's a pic of the 1.3L carby idle up bit.
Which bit do we change, the top screw or the bottom, or both?
Post Posted: Sat May 24, 2008 11:55 pm
bottom screw
then you need to follow the vacuum line of that actuator down to a little solenoid, thats the one you need to power via a switch, you also need to make sure it has a vacuum supply to it from the manifold
the one with the wire is an idle up for AC I think, though I dont think any work anymore
you can also fiddle the wiring a bit and wire the power steering pressure switch into it, so when the steering gets loaded up it ups the idle to help you along
Post Posted: Sun May 25, 2008 12:25 am
You can do Casper next weekend for me hey Royce, jussst a week b4 Tough Tracks round 2. :-) Love ya mate :wink: :roll:
Post Posted: Sun May 25, 2008 12:28 am
I think I might be a tad under the weather that weekend and cant make it :wink:
how many people actually have working idle up on their sierras?
Post Posted: Sun May 25, 2008 1:03 am
Mine works.......... except it is stashed in a shed at work for the next couple months
Post Posted: Sat May 31, 2008 10:02 pm
Well Casper's idle up is all working now thanks to Royce (again). It has a switch on dash. Idles when warm at 850ish, flick the switch and it goes to 1450ish. Just what I needed. Thanks mateeeeeeee. I'll give you another free months rent on my shed for that :-)
Post Posted: Mon Jun 27, 2011 7:28 am
Took a little while to find this again! Surprised it didn't get much interest.
Royce or anyone able to give a brief idea of how I'd set it up for both the pump switch and a manual switch from the dash?
Post Posted: Mon Jun 27, 2011 8:22 am
Mine works
did a DIY carby kit & everything works well
Post Posted: Mon Jun 27, 2011 9:30 am
Pump switch as in compressor? All you have to do with it is give it 12V. Then the solenoid will operate and push on the lever connected to the throttle shaft which will bring the revs up.
If its a single wire solenoid just apply 12V to it through your switch. If it has 2 wires one of them goes to ground, the other to your switched 12v supply.
Lil Foot!
Post Posted: Mon Jun 27, 2011 9:37 am
Sorry, power steering pump switch as Royce eluded to...
So pressure switch will need power, then dash switch and run both wires to the solenoid. Not being very electrical I'll just play around with it - sure I'll figure it out.
Post Posted: Mon Jun 27, 2011 9:43 am
12V -pressure switch- idle up solenoid- ground
as well as
12V - Dash switch - Idle up solenoid - ground
so you will have 2 switch wires going to the solenoid
Lil Foot!
Vehicle: 4wd
Post Posted: Mon Nov 07, 2011 11:37 am
I always wondered what the top solernoid was for. It's interesting that all carbys had them air conditioning or not.
Does that mean there is a wire for a load sensor in the Sierra engine bays?
Watch out or you'll get sued.
Post Posted: Mon Nov 07, 2011 12:59 pm
Now you have me wanting to find out how to turn on the vit TBI idle up with a switch. The idle up is controlled by a VSV and vacuum dashpot instead of a solenoid.
Thing is I think that 12v makes the VSV open which brings the idle down with vacuum, so I will need to cut power to get it to idle up. (If I have it right)
Vehicle: 93 Sierra
Post Posted: Mon Nov 07, 2011 2:33 pm
Yep I have idle up ... even have an in-cabin switch for it (kinda) - the rear demister switch in the hart tops kicks it in.
Post Posted: Mon Nov 07, 2011 7:40 pm
as well as
fail :)
to keep from rewiring the solenoid drastically
relay
87, to solenoid
30, to some kind of power
86, to power of some kind (both from the coil + will do)
85, to terminal on power steer pump and also tap off to switch
other terminal on switch gets earthed
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Tue Nov 08, 2011 12:32 am
I think it's the other way around. (Could be wrong though).
When I connected mine directly to the vacuum dashpot the idle rose by a couple hundred RPM.
I disconnected and blocked the pipe and revs are normal again.
It's a hassle cos I broke the little plastic bit that connects the two. :oops:
Post Posted: Tue Nov 08, 2011 1:49 am
as well as
fail :)
relay
87, to solenoid
Will it work? Yes. Is it easy for non electrically minded people to understand? Yes.
Anti_fail! :wink:
Lil Foot!
Post Posted: Tue Nov 08, 2011 2:04 am
as well as
fail :)
relay
87, to solenoid
Anti_fail! :wink:
Does the power steer pressure switch only have 1 terminal on it with the other side of the switch grounded via the pump case? Yes
Fail on your fail justification :roll: :wink: :lol:
Users browsing this forum: No registered users and 446 guests
