It is currently Fri Oct 02, 2026 8:24 am
Vehicle: Sj70 tintop
Post Posted: Fri Jul 01, 2011 9:56 am
94 maruti running a 1.3 sierra and 5 speed.
when the vehicle is cold, changing gears is really easy.
once the vehicle is at operating temp and higher, down shifting is really difficult, to the point that its almost impossible to get it into2nd than 1st.
it seems at operating temp that the clutch is not dissengaging properly, when i eventually get it into first, if i take the foot off the braker it creeps forward pretty quickly and sometimes i can smell clutch.
my question is: is this a clutch cable problem, or a wrong gear oil problem or adjustment problem?
and how can i fix it.
also the clutch an exeddy hd clutch and is about 2000km old.
cheers
Sj70 tintop
Post Posted: Fri Jul 01, 2011 9:58 am
have a good look at the cable
Post Posted: Fri Jul 01, 2011 10:05 am
how far do you have to depress clutch the peddle to when you feal the pressure if its more then 2cm it need to be adjusted
or you could go the with the rev between down gearing
cheers,
yeah i had a sneaking suspiscion, i have a new cable ready for it, just need to make it shorter.
i didnt change the cable when i changed the clutch so i geuss im reaping what i sow.
Sj70 tintop
Post Posted: Fri Jul 01, 2011 11:42 am
Id try adjusting the cable first and see how it goes.
The adjustment is easy just get under the car with a 14mm spanner and a shifter and tighten the nut on the end of the clutch cable where it joins to the gearbox. 1 turn might be enough.
Post Posted: Fri Jul 01, 2011 5:21 pm
yeah sounds like the cable. Happened to my sierra when it got hot after long drives. Turned out it had kink/bulge in the cable close to where is passes by the radiator hose.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Sat Jul 02, 2011 10:50 am
tightened the cable, felt better, shifted well but came loose again, might have a buggered tensioner, will have a better look 2moro.
Sj70 tintop
Post Posted: Sat Jul 02, 2011 10:58 am
i just had a problem like this. was a unknown useage clutch but (turned out to be pretty much worn)
it was hard to get into gears. tightened cable. drove for a while. started to be hard to change again. tightened. hard to change again.
pulled it out and the throwout bearing was mangled big time. throwout bearing was noisiy but. probably not same problem as yours. similar in the keep tightening thing but so i dunno
Post Posted: Sun Jul 03, 2011 4:26 am
tensioner was buggered, made a new one, problem solved.
cheers
Sj70 tintop
Post Posted: Mon Jul 11, 2011 8:10 am
anyone have a pick of the clutch cable tensioner? mine is buggered beyond recognition and i need to see the order of the rubber boot and the spring etc. i dont have the spring anymore i think its in peices on the road some where.
Sj70 tintop
Users browsing this forum: Google [Bot] and 114 guests
