+12v Thick white
Earth are black, make sure at least one of your earths is BOLTED to a solid earth you run yourself
Ignition on Black/white
Door youll have to run
Immob 1, same black/white, but cut it in downstream of ignition on
Immob 2, Starter should be black/yellow
You could also instead cut the power to the shutoff valve for the gas, if you can get to it neatly
I'm installing this immobiliser into my new zook, it's all good and I only have the ignition line to wire up, but i'm double guessing myself with this concept of negative switching. I just want to confirm the definition of "downstream" - does that mean on the key barrel side of the immobiliser or on the firewall loom side?
