It is currently Thu Jul 30, 2026 4:17 pm
Post Posted: Tue Jul 05, 2011 8:16 am
hey guys.
so my jimny has been copping quite a bit of thrashing lately and i have smashed my rear shockies and bent them.
im running 4.5 - 5" spring lift
does any body know where i can get some decent long travell shocks locally.
(brisbane)
Other then the ranchos.
bryce.
Post Posted: Tue Jul 05, 2011 10:30 am
:blink: wht did u do?
Vehicle: Jimny
Post Posted: Tue Jul 05, 2011 10:35 am
what do you think of the ORA kit bryce
DONT BUY A GQ! zooks are better. i have both :)
if u get a measurment ill check my list tomorrow on wat tough dog will suit, then u can go to your local dealer and get them to order the exact 1s in, cause they will have to be modified
dodgy brothers mechanical
Post Posted: Mon Jul 11, 2011 8:44 am
brought rancho rs5000's
As for the kit
not to bad springs are a bit to soft. caster bushes supplied are total rubbish!!!!!!!!! lasted about 3 months. shockies lasted about the same. spings in rear have sagged about 1/2"
no entended bump stops etc.
Post Posted: Mon Jul 11, 2011 8:47 am
just had new shockies put in .
Transfer case cross member cut and re welded a u" bent steam pipe in as the drive shaft was hitting.
looking at getting the gearing done next month or so along with some 6" springs and 2" body lift
hopefully running 32" tyres.
still alot to go
Post Posted: Tue Jul 12, 2011 7:48 am
still alot to go
Not going to happen mate! The panhard rod fowls on the spring once you go over 4.5inch's of lift with the springs, so unless you are going to move all the springs mounts, shocks mounts the pandhard rod will fowl on the spring and why the hell would you want to go that high anyway :? ?
If you look at the ORA car, they are running 4.5"lift with 2" Bl with 33's! This is the way i would go, chop the guards, extend the bump stops, lock it gear it and keep it low 8)
JMO of coarse!
Post Posted: Tue Jul 12, 2011 8:13 am
JMO of coarse!
WHAT!?
Post Posted: Tue Jul 12, 2011 8:14 am
SierraDan wrote:
JMO of coarse!
WHAT!?
I'm just saying that's what they run to have the 33's, i'm not saying that;s what he should run :wink:
Post Posted: Tue Jul 12, 2011 8:21 am
monkey wrote:
SierraDan wrote:
JMO of coarse!
WHAT!?
okay haha. i was gonna say. I sometimes dont like how high mine is haha.
Post Posted: Tue Jul 12, 2011 1:11 pm
well mine has the tough dog kit a body lift and i have moved the diff forward, a bit mor chopping to the flare and a bit more on the back i could easily run 33s, i just wouldn be able to hit sand dunes at high speed but crawling would be no problem
Post Posted: Wed Jul 13, 2011 4:08 am
still alot to go
:crazy: wooow are you sure?????.... seems you re just trowing numbers there donno hahaha
IMO 31s re waaay more than enough for a jimny... heaps of ground clearance (more than other big rigs with 33s or 35s)... also if Im not wrong 31 is pretty much the top of wht the jimny driveline can handle... more than that is just asking for trouble
and 6" springs plus BL????? :crazy: men have u look under the plastic/steel wheel arch.... there is heaps of space there u just have to chop chop to get it..... and if u want to let ur factory look flares there is a guy in the bigjimny site who design flares that optimize the wheel arch and look factory (he's running 33s in 15x8 rims)... or buy the japanese ones too
with your 4.5" lift u have enough space there to ft the 31s if u chop chop.... if u want more ad a bit of bodylift... but 6" i think is just crazy... u are entering in a more complicated suspension custom design... and adding a bodylift in top of that is waaay too much IMO
and out of curiosity where re u gonna get 6" springs for jimny??? the longest available re the 4.5 that u already have
well good luck wiht ur monsterjimny build... and post more pics of it :helloo:
Post Posted: Wed Jul 13, 2011 8:11 am
Custom spring's Bert at a guess
Post Posted: Thu Jul 14, 2011 8:44 am
hey guys.
yes the car is getting worked on atm. getting it all sorted and ready so it will handle the bigger lift and tyres.
once all done i should beable to go to a 34" tyre max but IMO thats to big !!
Gearing is getting done.
springs will be custom.
shockies are suited all ready to run a 6" spring .
2" BBL will be going in soon....
engine.
Ported and polished
re mapped/tuned
full exhause
Air intake
just for now.
i do have a sc12 charger waiting to be put on :( its just a very costly process.
Post Posted: Thu Jul 14, 2011 8:46 am
bryce wrote:
hey guys.
engine.
Ported and polished
re mapped/tuned
full exhause
Air intake
just for now.
8O 8)
But what about the issue of panhard hitting the springs? :?
Post Posted: Thu Jul 14, 2011 8:48 am
dude i have got no clue on where you are looking but i have a solid 4" between spring and panhads!
Post Posted: Thu Jul 14, 2011 10:09 am
:helloo: dnt forget to take pics and update ur build tread
Users browsing this forum: No registered users and 295 guests
