It is currently Thu Jul 30, 2026 12:01 pm
Post Posted: Mon Aug 29, 2011 10:19 am
Hey i have got a coily with a 2''sus and a 2''body lift do you think 32/10.5/r15s will fit ?
Post Posted: Mon Aug 29, 2011 10:20 am
should do :) want 33's has a similar set up and he runs 33's :wink:
Post Posted: Mon Aug 29, 2011 10:21 am
Yes and no, you'll need some hammering and bumpstop spacing.
Steve
Post Posted: Mon Aug 29, 2011 10:28 am
This one was in our club a while back.
It ran 31's I think.
gwagensteve would know more detail
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Aug 29, 2011 10:32 am
Hammertime!
Post Posted: Mon Aug 29, 2011 10:33 am
I just crammed 31's under my coily with said amount of lift. I reacon I'll be struggling for it not to rub without decent massaging with a hammer and bump stop alterations
Post Posted: Mon Aug 29, 2011 10:44 am
thanks
Post Posted: Mon Aug 29, 2011 10:46 am
Oh I thought I had forgotten somthing! :oops:
Steve
Vehicle: SJ50 hardtop!
Post Posted: Mon Aug 29, 2011 10:56 am
My mate has 31" silverstonea on his coily with 2" sus and 2" body. Clears them nicely. There also on a very deep dished rim
NT SJ50
Post Posted: Mon Aug 29, 2011 10:58 am
I has 31's with 2" spring lift. Clears them nicely ;)
Vehicle: 4wd
Post Posted: Mon Aug 29, 2011 11:00 am
I has 31's with 1.5" spring lift and beat guards. Clears them nicely ;)
Watch out or you'll get sued.
Post Posted: Mon Aug 29, 2011 11:02 am
But your zook fell on it's head ;)
Post Posted: Mon Aug 29, 2011 11:45 am
My old zook. 32x11.5 on 8" rims. Cleared with 2" BL, 2" springs, guards hammered in and front diff moved 22mm forward
Member of C.O.R 4x4
Post Posted: Mon Aug 29, 2011 12:06 pm
You guys aren't helping with the leaf tech. Coilers run a wider axle and different roll centre and scrub radius - they don't fit tyres the same way.
The Red HT with the 'pedes on it ran a custom Koni-based suspension kit, 2" BL, and about 20mm of bumpstop spacing, with hammered seams. Bumper outrigger had to go. Wheels were ROH Trak II on a stock vitara offset, from memory.
I don't know the measurements of 31" 'pedes but it's fair to assume a 32" tyre should be a bit bigger, so bumpstop spacing and more hammering would be required. Wheel offset will be critical.
Post Posted: Mon Aug 29, 2011 12:47 pm
My old coily - 31's, 2inch spring, 2inch body lift and slight hammering.
The 31's cleared alright but i'd say you will need to so some serious hammering or maybe even some cutting. Gearing wasn't great with the 31's in low but if you sort that out i can't see it being to hard fitting 32's.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Mon Aug 29, 2011 1:01 pm
My bad, missed the coily bit. Good luck with it then :peaceout:
Member of C.O.R 4x4
Post Posted: Mon Aug 29, 2011 7:53 pm
thanks boys
Users browsing this forum: Google [Bot] and 299 guests
