It is currently Fri Jul 31, 2026 5:42 am
Post Posted: Tue Sep 06, 2011 1:10 pm
OK so i am building a W/T diff for the front of my coiler atm...
specs are
3.9 c/p second hand, will set tolerances as tight as within spec will allow.
wt flange
powertrax locker
Rock Assault 4340 Chromoly Axle Shafts
vit calipers
all new bearings
i will laminate all arms
housing has been shaved, trussed, crown wheel guard and knuckle gussets.
is there anything else i should look at doing? i am wanting to run 34inch tires so lots of load on this one! and i would like to not have to touch him again other than usual maintenance
possibly this
http://www.lowrangeoffroad.com/index.ph ... t-kit.html
not much to add on to the build..
i will also be doing a similar amour of work to the rear housing (w/t) so any ideas that way will help
Phil
Post Posted: Tue Sep 06, 2011 7:22 pm
If u upgrade them u might start breaking cromo cv
Post Posted: Tue Sep 06, 2011 7:27 pm
Try a 4 pin front center, I know 3.9s usually come with them but I thought for everyone else it was worth mentioning...
Online
Post Posted: Tue Sep 06, 2011 8:27 pm
use a solid pinion spacer not the crush spacer.
Post Posted: Tue Sep 06, 2011 9:51 pm
ok i have a 4pin already :) (well a pair of them)
where would i buy a solid spacer?
Post Posted: Tue Sep 06, 2011 10:50 pm
aparently one of the hilux ones can be used.
there was a discussion on this a while back and it was decided that a solid spacer wasnt really needed
Post Posted: Wed Sep 07, 2011 6:22 am
is it worth going to grade 12 shcs bolts on king pins?
Post Posted: Wed Sep 07, 2011 7:37 am
I dont think you need half of the crap in your original post to run 34's , just cromos and locker
Post Posted: Wed Sep 07, 2011 7:38 am
What about 35's?
Post Posted: Wed Sep 07, 2011 7:41 am
your probably right.. but cant hurt to beef it up a bit more than required.
i also want to run a front dig.
Post Posted: Wed Sep 07, 2011 7:49 am
Isnt front dig when you have rear disconnect and a line locker?
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Sep 07, 2011 7:57 am
make sure you set the castor properly for your ride height and go back to stock suzuki rubber bushes if you've been using castor correction bushes.
LIKE US ON FACEBOOK - KPD4x4
8) prob wont go line locker, will just get handbrake working spot on.
Post Posted: Wed Sep 07, 2011 7:59 am
yeah dank thats all under control. i will be setting the caster to 4degrees at ride height with standard arms... i will be making high clearance tube arms but with the option of using a stock arm if the situation calls for it.
Post Posted: Wed Sep 07, 2011 8:03 am
you should just put leaves in and all will work :wink:
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Sep 07, 2011 8:10 am
Hahahahahahaha
Post Posted: Wed Sep 07, 2011 8:12 am
and be just like you? nah..
Users browsing this forum: No registered users and 526 guests
