| Author |
Message |
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Mon Sep 05, 2011 12:24 am |
Has anyone had any experience with the 6 ply treps that come in 30 x 9.5's? Are they a good tyre for the money? I'll be running a g16b, 6.5 gears and stock WT diff gearing. Will these tyres be too small for driving on the highway? Ps. In a Sierra.
tanshi
 Posted: Mon Sep 05, 2011 12:25 am |
30s will be far to small to use with 6.5s
Fatzook
 Posted: Mon Sep 05, 2011 12:33 am |
sogone wrote: Has anyone had any experience with the 6 ply treps that come in 30 x 9.5's? Are they a good tyre for the money? I'll be running a g16b, 6.5 gears and stock WT diff gearing. Will these tyres be too small for driving on the highway? Ps. In a Sierra.
My mate runs exactly the same combo in his sierra, except he only has 4.16:1 gears. Runs VERY well. IMO you should get some 4.9's if you don't plan to run bigger tyres than 31".
Treps go very well offroad from what I have seen. They bag nicely at 14psi.
sogone
 Posted: Mon Sep 05, 2011 12:56 am |
As in 4.9 diff gears? I've already got the 6.5 transfer gears.
How's his go driving round on the road Fatz? Can he sit comfortably on 110 or is it ringing it's neck with such high gearing and only 30's?
tanshi
 Posted: Mon Sep 05, 2011 1:19 am |
with 6.5s your going to be doing
3760 at 100km/h
ZookiMonsta
Joined: Sun Aug 23, 2009 11:30 pm Posts: 1625 Location: Jimboomba
 Posted: Mon Sep 05, 2011 2:16 am |
I run 30" Treps with 4.16 as well as a G16b and it's awesome! You wouldn't need any lower transfer gears, heaps of power on the road and it's plently low enough in 1st low to crawl everything I've pointed it at! IMO don't bother with 6.5s on anything under 32's, it's just way too low for general 4wding.
_________________ Own a weird looking coily sh!tbox!
sogone
 Posted: Mon Sep 05, 2011 2:20 am |
Mmm. Already have the 6.5s. Might see if I can find some 32's.
sogone
 Posted: Mon Sep 05, 2011 2:27 am |
Actually Joel would probably buy my 6.5's. Where do I find the 4.16's?
tanshi
 Posted: Mon Sep 05, 2011 2:28 am |
sogone
 Posted: Mon Sep 05, 2011 2:32 am |
When you guys are talking about 4.26's... Are ya talking about diff gears or transfercase gears?
tanshi
 Posted: Mon Sep 05, 2011 2:35 am |
4.26s??
i think you meant 4.16 and were talking about transfer gears
Fatzook
 Posted: Mon Sep 05, 2011 3:20 am |
tanshi wrote: 4.26s?? i think you meant 4.16 and were talking about transfer gears
4.26'S are Vitara gears.
sogone.....
If you sell your 6.5's to Joel, buy the 4.9:1 transfer gears from Lowrange. They are slightly lower than the 4.16's, and will give you gearing to suit 30-32". That way you can always jump up a tyre size or 2 without having to re-gear. I think the 4.9's are about the same price as the 4.16's anyway.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Mon Sep 05, 2011 3:33 am |
Fatzook wrote: tanshi wrote: 4.26s?? i think you meant 4.16 and were talking about transfer gears 4.26'S are Vitara gears. sogone..... If you sell your 6.5's to Joel, buy the 4.9:1 transfer gears from Lowrange. They are slightly lower than the 4.16's, and will give you gearing to suit 30-32". That way you can always jump up a tyre size or 2 without having to re-gear. I think the 4.9's are about the same price as the 4.16's anyway. 4.9s are dearer then 4.16 and 6.5s
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
sogone
 Posted: Mon Sep 05, 2011 3:48 am |
Sorry meant 4.16's. Fat fingers.
sogone
 Posted: Mon Sep 19, 2011 4:07 am |
Ok so next question. I'm looking at running a Aw4 or the trimatic. Assuming I keep the 6.5's and run a 32 how would these autos work with the tyre size and the 6.5's? What would my highway revs be at 110k's an hour? For both boxes. Anybody else run this set up? Any experience with it?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Mon Sep 19, 2011 4:16 am |
Trimatic will be WAY too low geared. I get 4250rpm @ 100km/h and an actual 30" tyre, 4400@29"
An AW-4 will gear you back to about 3500rpm @ 100km/h with a 29" tyre.
AW4 is the answer. Fair hassle to fit though, wheelbase wise. Jackshaft and rear driveshaft lengths become a fair balancing act.
I've been involved in a couple of Trimatic builds and recommend them for over 33" tyres, but they are pretty hard to make workable under that.
I'm going AW-4, but I am LWB.
sogone
 Posted: Mon Sep 19, 2011 4:26 am |
Ok, So what if I went to a lower reduction in the transfercase. Like 4.9's or the 5.12's? Will this make the trimatic bearable on the highways? It's not gonna be used for rock climbing, it's gonna be used to get out to our hunting spots, will have a bit of mud work to do.
FHA57
Joined: Thu Dec 16, 2010 5:35 am Posts: 179 Location: sunshine coast
 Posted: Mon Sep 19, 2011 4:33 am |
what rpm at 100kmph in fifth do u get with the g16b and 4.16:1 gears?
sogone
 Posted: Mon Sep 19, 2011 4:35 am |
With what size tyre FHA57?
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Mon Sep 19, 2011 4:40 am |
FHA57 wrote: what rpm at 100kmph in fifth do u get with the g16b and 4.16:1 gears?
Sierra with 4.16s and 30s? I'd say around 3200?
_________________ I want my old sig back
FHA57
 Posted: Mon Sep 19, 2011 5:44 am |
yeah with 30's i have a g16b in mine with 30x9.5 maxxiss 764 bighorns with neg 12 offset f100 rims stock wide track transfer gears atm also have stock wide track diff gearing would it be worth me spending the bucks to get the 4.16 gears? what rpm will it do at 100kph with stock transfer gears? i havent got it regoed yet been going over the zook fixing anything i can to make it awesome.
FHA57
 Posted: Mon Sep 19, 2011 5:45 am |
btw thanks ben ur adapter was awesome
sogone
 Posted: Mon Sep 19, 2011 5:50 am |
Geez thread high jack much?
FHA57
 Posted: Mon Sep 19, 2011 5:55 am |
haha sorry  but thought itd help u too
imo 30's are the best ive ran 31's with stock transfer case of a 1.3 and it sucked 30's and the g16b are a lot different but wondering with the transfer options as well is it really worth it?
Ben_Sierra
FHA57 wrote: btw thanks ben ur adapter was awesome
What adaptor?
FHA57
 Posted: Mon Sep 19, 2011 5:56 am |
and as for your question the trepadors are a great tyre saam ran them on his coily and they were awesome
Ben_Sierra
 Posted: Mon Sep 19, 2011 5:57 am |
FHA57
 Posted: Mon Sep 19, 2011 6:39 am |
oppps didnt read properly sorry thought it was ben t for a sec lol
