It is currently Wed Nov 04, 2026 8:07 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Sun Sep 18, 2011 10:32 pm
We have higher amibient temperatures down here than you do shep
Steve, you have never been more wrong in your life.
Post Posted: Sun Sep 18, 2011 10:35 pm
When was the last time it was 46 degrees in Darwin?
Post Posted: Sun Sep 18, 2011 10:43 pm
Post Posted: Sun Sep 18, 2011 10:46 pm
hahahaha. ^^
Post Posted: Sun Sep 18, 2011 11:05 pm
I was commenting on Darwin and surrounds, not further inland. I understand Shep has only recently moved to Katherine.
Post Posted: Sun Sep 18, 2011 11:09 pm
But Sheps not from Darwin? And you did mention that you have higher ambient temps then Shep does... Which you don't.
I'm just confused on what your saying here gwagon.
Post Posted: Sun Sep 18, 2011 11:23 pm
Did Shep live in Darwin ?
Post Posted: Sun Sep 18, 2011 11:57 pm
Here we go. *sigh*
Shep upuntil recently lived on the coast, No? Elcho island, whilst some distance from Darwin, is likely to see a generally similar climate to Darwin it is at about the same latitude and also surrounded by water, no? Peaks about mid 30's?
I can't comment on how much experience Shep has with his current thermo setup in Katherine, where, quite rightly, you point out the temperature does get very hot, but I bet he's not climbing many steep low 2nd tracks for an hour or so at at time, at low vehicle speed/high engine load.
I was only trying to point out that not everyone's experience is the same or strictly relevant for everyone else. This is a big country and it's very clear that what works in one place won't work in another.
The assumption that many would make is that because shep lives in the NT he must have the best sorted thermo setup ever because of the local conditions. I'm just pointing out it might not be all it looks like on face value.
No offence at all to Shep - if it works, it works - it just might not work everywhere, or even in Melbourne.
Let's not turn this into a pissing contest about who has the most hardcore weather. It's only relevant as much as outright cooling capacity required is a function of ambient temp and load. We might well be able to see the same or greater demand on a cooling system here in victoria.
Post Posted: Mon Sep 19, 2011 6:47 am
I reckon you have rocks in your head to trust the running temp and life of an engine that's already finicky with being run too hot to something that isn't the simplest failsafe method possible, which just so happens to flow the most air
The only good thing about the thermo on my sierra was I got to see more countryside cause I could only do 90 before it started running hot, and before all you noobs pipe up with what I did wrong just remember some people have been doing this on these cars for a long time and have tried it all :wink:
Wow 8O If the sierra can't cool itself through ram air at 90 without the aid of fans, whoever designed that was a complete retard...
Post Posted: Mon Sep 19, 2011 6:57 am
It most likely does WITHOUT a thermo blocking its way!
Lil Foot!
Post Posted: Mon Sep 19, 2011 6:58 am
Lol I thought ignition coils were your expertise not ambient temps :lol:
Lil Foot!
Post Posted: Mon Sep 19, 2011 7:00 am
Damo wrote:
I've run a 16v 1.6 in my Sierra for years with the stock rad with no problems.
Pigs ass!! :thefinger:
Lil Foot!
Post Posted: Mon Sep 19, 2011 7:08 am
I prefer Thermos. But I never buy cheap ones. And I always upgrade the radiator too. This practice has not let me down yet.
As for fitting a thermo to a standard radiator.... I cannot comment, as I am yet to try it.
Post Posted: Mon Sep 19, 2011 7:48 am
:roll:
Post Posted: Mon Sep 19, 2011 7:51 am
steak_knife wrote:
:roll:
Good news.
Post Posted: Mon Sep 19, 2011 7:52 am
steak_knife wrote:
:roll:
Good news.
Vit clutch fan over ANYTHING!!!! :helloo:
Post Posted: Mon Sep 19, 2011 8:10 am
steak_knife wrote:
steak_knife wrote:
:roll:
Good news.
I agree with you on principle. But I always mount my G16's lower than the 'kits' allow, and that makes it impossible to line up the fan and the radiator shroud.
Post Posted: Mon Sep 19, 2011 10:00 am
:roll: Just cause you can :roll:
Post Posted: Mon Sep 19, 2011 10:06 am
Yep.
Post Posted: Mon Sep 19, 2011 10:07 am
Yep.
Camo going yet???
Post Posted: Mon Sep 19, 2011 10:11 am
haha i am from katherine and only spent 2 years at elcho.
true story. i spent 6 years living at port macquarie in NSW and port was hotter then katherine
and katherine is colder then port. haha
the issues i had were all to do with going slow with no revs in a swb hard top sierra with a 8v g16
and the aircon on flat out.
steak_knife wrote:
Yep.
Camo going yet???
Moved to FNQ yet? :P
Post Posted: Mon Sep 19, 2011 10:14 am
steak_knife wrote:
Yep.
Camo going yet???
:thefinger: not yet!!!
Post Posted: Mon Sep 19, 2011 2:42 pm
How does a thermo fan block air flow ?
When i go below around 40k for extended periods my thermo will cut in, never above.
Post Posted: Mon Sep 19, 2011 3:07 pm
What's the PCD on the Vit clutch fan?
Or more to the point, will it fit an F8a?
Post Posted: Mon Sep 19, 2011 8:15 pm
They werent designed to be cooled with 'ram' air, they are a 4wd FFS not an F1 car
Post Posted: Mon Sep 19, 2011 8:18 pm
regardless of it being mounted on the front or rear of the radiator the fan blades are always covering a section of core, so that section even for the slightest instant is not getting any airflow through it.
Eventually you are moving faster than the fan blades are able to pass air, even with the extra flow they are capable of once you introduce the higher pressure 'ram' air in front of it so it acts like a big wall preventing more air through
Post Posted: Mon Sep 19, 2011 8:23 pm
Biggest flowing fan you could get to fit between the confines of the top and bottom of the radiator, even changed the actual fan section to one with more blades, still didn't work.
Sierra front ends arent designed to funnel air through a radiator, the radiator isnt designed to be cooled by just moving through the air, simples
Vitara radiator is a different story, its larger surface area grabs more fresh air
Post Posted: Tue Sep 20, 2011 12:17 am
That all makes sence. And I assumed that because there is a larger radiator fitted to the vitara from the factory, that the G16 would require an increase in cooling capacity that a standard sierra radiator cannot give.
Another issue with peoples' use of thermo fans in place of engine or viscous fans, is that they remove the shroud to give room for the thermo fan.
Surely having an un-shrouded thermo is less effective than having a shrouded one? :?
Airflow volume, AND patterns through the front of a sierra would be suspect at best, so relying on 'ram' air is not a well thought out plan.
Post Posted: Tue Sep 20, 2011 12:36 am
I dont reckon that kind of shroud is required with a thermo, the important part is the circular band around the blades is required to get the blades to pull air from in front and not radially.
My opinion is covering the core like that is restricting airflow once you are moving and forcing it through the fan opening or more likely passing air around
I like the idea of air dams between grille and radiator to get all the air coming through the grille to go through the radiator if you cant sjut fit a wider one
Users browsing this forum: No registered users and 213 guests
