It is currently Wed Sep 23, 2026 5:47 am
Post Posted: Mon Sep 19, 2011 9:35 pm
Ive searched and havent quite found the info i need. Im in the process of swapping a g16b into my sierra and am gonna run with the standard 5 speed, my question is will a standard clutch handle the power or is it worth the extra money and going with a heavy duty unit. Im running 4.9's and 31's so i currently dont really have to slip the clutch offroad but with the extra power im not so sure about high range. Also what brands are worth looking at and where to get em. cheers guys :)
tintop, barwork, locked Front , RUF, 4.9's, 31's :
Post Posted: Tue Sep 20, 2011 12:26 am
Get a standard EXEDY clutch. They are more than up to the challenge og a G16B.
Vehicle: Sierra Ute '87 Sj70
Post Posted: Sun Sep 25, 2011 10:27 am
While your going why not go the exedy hd clutch?
It's all coming together Armsup
Post Posted: Sun Sep 25, 2011 10:37 am
In my opinion, and only in my experiences,
the surfaces that clamp together are more important to grip,
and life of the clutch,
than the tension that they are under.
Heavy duty often means just a harder spring plate,
hard work on your leg,
and a bitch to the cable on cable operated clutches.
Post Posted: Sun Sep 25, 2011 11:10 am
Oh ok
Thanks and probs cheaper
Post Posted: Sun Sep 25, 2011 11:13 am
Fatz, Im hoping to do an engine exchange soonish, I know you always say exedy, so I went in search, found this.
There is 2 clutches for the g13ba, which in in my car now, both have the same years, how do I ID which engine series/clutch for the toy.
Post Posted: Sun Sep 25, 2011 11:15 am
one is for the button type one or w/e
i just clicked on both and had a look at diferances
Vehicle: 2018 DMAX
Post Posted: Sun Sep 25, 2011 11:16 am
Are you sure its not fly wheel differences? you can get flat and stepped flywheels..
Post Posted: Sun Sep 25, 2011 11:25 am
it could be that too i have no idea
Post Posted: Sun Sep 25, 2011 11:26 am
Post Posted: Sun Sep 25, 2011 11:27 am
There are 2 different spline counts for the sierra gearbox input shaft. That is why there are usually 2 part numbers. One is everywhere, and the other is so rare it may aswell not be mentioned.
Not sure which is which though :oops:
Post Posted: Sun Sep 25, 2011 11:43 am
So its pull the donk out, ID the spline count, then order the clutch, dam, was hoping to have everything ready, oh well.
There is 3 of one and only one of the other, it may be the single, SZK 6293 is the rare bird, so order the other.
Can only fail.
Post Posted: Sun Sep 25, 2011 11:45 am
A decent clutch place sent me home with two,
bringing back the unused one.
Its worth trying
Post Posted: Sun Sep 25, 2011 11:48 am
Can only fail.
Yeah sorry I couldn't be more helpfull. Stekky or Scrawn may have the answers you seek though..... :?
Post Posted: Sun Sep 25, 2011 12:04 pm
Its all good, when I id mine I will give details.
Order two, return one, yep, sounds good, they should understand that.
Users browsing this forum: Google [Bot] and 182 guests
