It is currently Sat Oct 31, 2026 10:26 am
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3
Post Posted: Wed Sep 21, 2011 7:57 am
make a video and post it up for us to see (burnouts are encouraged)
Post Posted: Wed Sep 21, 2011 8:11 am
awesome, sounds like your really happy with it. i could only imagin how much fun it would be in the wet haha
i would imagin when buying a m18 it would come with injectors already for that motor so they should be no problem, only thing i would suggest is a bigger fuel pump but even that should be ok to cope. ecu should adjust but im sure it wouldnt be too hard to get a m18 ecu anyways.
video would be awesome too
Post Posted: Wed Sep 21, 2011 9:10 am
m18 computer is fine, but the immobiliser bit is the bitch.
Post Posted: Wed Sep 21, 2011 10:07 am
This thing dose sick skids :lol:
Post Posted: Wed Sep 21, 2011 10:14 am
My names monkey and I try to roll peoples zooks testing their engine upgrades :P
Post Posted: Wed Sep 21, 2011 2:40 pm
skyman wrote:
Don't the ecu's look for stoichiometric, and adjust fuel accordingly?
as long as the injectors can keep up it should be good no matter what ecu it runs?
Granted timing and such will not be optimum for the engine that is being installed (should be pretty close?) , but mixture should be the go, unless the injectors are too small?
Am I missing something here?
ECU's only adjusts to stoich AFR when in closed loop, which is generally <75% load. At 75%-WOT it runs of a pre determined fuel map for that particular engine including injector size.
Lil Foot!
Post Posted: Sun Sep 25, 2011 9:50 pm
just another question i thought of, since the m18a engines are hard to come across now what are parts for them like? easy/hard to get etc etc?
atleast there is loads of m15a motors laying around so parts would be no problem for them
Post Posted: Tue Nov 08, 2011 12:10 pm
http://www.ebay.com.au/itm/Suzuki-LIANA ... 463wt_1163
bit steep?
2004 Jimny
2" ome lift
15mm spacers
235 75's
Users browsing this forum: Google [Bot] and 194 guests
