It is currently Fri Jul 31, 2026 3:59 am
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2  Next
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:22 am
I want to lower my zook as it's sitting to high. I only have a 40mm lift, but would like to bring it back to stock height.
Running OME's all round will it drop the ride height if I remove a leaf from each pack?
Watch out or you'll get sued.
Post Posted: Wed Sep 21, 2011 9:26 am
Why not just put stock springs in? :?
Post Posted: Wed Sep 21, 2011 9:27 am
but why ?
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:38 am
I like the flex of the OME's, but that is an option.
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:39 am
tobeszook wrote:
but why ?
Why what?
Post Posted: Wed Sep 21, 2011 9:40 am
how low do you want to go?
could you not remove 2 leaves & add on stock one to to each pack? (if you've got any stockies?
Post Posted: Wed Sep 21, 2011 9:42 am
taking a leaf out would do it, but you'd potentially get handling issues, and you'll need to check the shocks wont bottom out on compression.
another option being that you're SPUA is lowering blocks between the leaf and the diff =P hahaha
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:43 am
I'd like to go 30-40mm lower. I do this have stock springs so that is another option.
Vehicle: Sj70 tintop
stockman wrote:
tobeszook wrote:
but why ?
Why what?
if its only 40mm lifted, why bother lowering it anymore?
low is the new cool, but a lowriding zook is ghey.
Sj70 tintop
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:44 am
:rofl:
Post Posted: Wed Sep 21, 2011 9:45 am
swap the stock main leaf with the OME one, so you have the OME main and stock pack underneath... then you get the longer leaf and flatter spring.
i drove a stock sierra on the weekend (suspension was stock, engine was 1.6efi - it hauled ass on stock tyres!!) the ride from stock leaves is best described as "the bumpiest fucking ride of your life" IMO..
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:46 am
joel wrote:
stockman wrote:
tobeszook wrote:
but why ?
Why what?
To lower the cog.
Lowering it 30-40mm will hardly make it a lowrider. :roll:
just buy a mini moke, that should be low enough.
Sj70 tintop
Post Posted: Wed Sep 21, 2011 9:48 am
stockman wrote:
joel wrote:
stockman wrote:
tobeszook wrote:
but why ?
Why what?
To lower the cog.
a 40mm lift will hardly make it a high cog. maybe a 40mm lift, 2'' shackles 3''bl and your best driving suit with matching top hat.
i reckon just leave it man, your fixing what isnt broke IMO
Sj70 tintop
Post Posted: Wed Sep 21, 2011 9:49 am
why bother?
cause in 8 days 5 hours & 42 minutes you'll probably change your mind. :P
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:50 am
You obviously can't read or are retarded or quite possibly both.
Post Posted: Wed Sep 21, 2011 9:52 am
possibly, but im not trying to lower my 40mm lifted zook :thefinger: :peaceout:
Sj70 tintop
Vehicle: 4wd
why bother?
This is quite possibly true,
But on stock tyres I don't need to have 20" of guard clearance :lol:
Post Posted: Wed Sep 21, 2011 9:53 am
joel wrote:
stockman wrote:
joel wrote:
stockman wrote:
tobeszook wrote:
but why ?
Why what?
To lower the cog.
sounds more like you know a whole lot of fuck all about anything to me :roll:
maybe help the guy , or dont bother fucking his thread.
you could probably make a hybrid pack using the main ome leaf or two (to get the droop) and some standard leafs.
you just have to play around to get the ride you want
a locked stocker with muds & long soft leaves would be a ball to drive. 8)
Post Posted: Wed Sep 21, 2011 9:54 am
I would put the stock ones back in.
You will ruin the OME springs if you start flattening them out by changing in other leafs.
Post Posted: Wed Sep 21, 2011 9:55 am
stockman wrote:
why bother?
but you dont :roll: you have less then 100mm to the stock bumpstop possie.
Post Posted: Wed Sep 21, 2011 9:57 am
:roll:
Post Posted: Wed Sep 21, 2011 10:03 am
ajsr wrote:
joel wrote:
stockman wrote:
joel wrote:
stockman wrote:
tobeszook wrote:
but why ?
Why what?
To lower the cog.
that is my advice, just leave them in there i reckon, how old are the sprigs?
if they have done a fair few kms they would have settled a bit, mine have and are nearly flat.
i geuss if you have the spare time and what not, than do it.
but i would just leave it, ome are nice springs and far better than stockers,
if you pop a spring out of them they may be to soft and invert after a while like my old ones.
Sj70 tintop
Post Posted: Wed Sep 21, 2011 10:08 am
hey joel, you should sell him your calmini shackle reversal kit. :wink:
Post Posted: Wed Sep 21, 2011 10:10 am
sad fact is, i still have it in the shed and havent binned it where it belongs
the front end was so much smoother and softer with it in, pitty everything else about it is crap.
Sj70 tintop
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 10:13 am
Thanks guys, Exactly the input I was wanting to here.
RIKSTR wrote:
:roll:
:roll:
stockman, what rim offset do you run? widening it could be another option.
mines pretty wide with 15x7 -38 rims and 31x10.5 tyres.
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 10:15 am
Just standard rims, not sure on the offset.
I don't really want a big off set rims, as with narrow tyres I'm just going to fall into the ruts.
Post Posted: Wed Sep 21, 2011 10:20 am
ah, righto...
hey if fabrication is your thing you could make lower spring mounts off the chassis, and set the shackle end up like this, but not in reversal:
Users browsing this forum: No registered users and 535 guests
