It is currently Sat Aug 01, 2026 11:12 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2
Vehicle: Sj70 tintop
Post Posted: Wed Sep 21, 2011 10:25 am
can you explain whats happening and how and why thats good? is it like a simpler elliptical type scenario?
Sj70 tintop
Vehicle: '92 Sierra
Post Posted: Wed Sep 21, 2011 10:39 am
Looks like a stock front lux shackle to me. I imagine from the factory they mounted the shackle this way to get around the necessary dropped mounts (fangs) at the front to counter an underchassis shackle mount. Keep in mind that's just a guess.
Post Posted: Wed Sep 21, 2011 10:46 am
its not good or bad other than it would lower the chassis and COG by like 2"... you'd need to make custom shackles i would think.
Post Posted: Wed Sep 21, 2011 10:51 am
woo 2 pages of useless :)
don't remove leaves, it will be lower cause its softer, then when the leaves cant hold up the weight anymore they will get lower and lower and lower :)
rip em out, take em to a suspension place that can reset leaves (probably has a lot of trucks to work on) and ask em to make em 40mm flatter, doesn't get any simpler than that
at one stage I was going to do this on my new zook, but it has a few issues with shackle travel when you really twist it all up, so I decided against it .
could be cool though
Post Posted: Wed Sep 21, 2011 10:53 am
is it running 2 shackles on the rear spring?
or has it done a s/r to the rear spring?
yes im a simpleton.
Sj70 tintop
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 10:55 am
:D That sounds like a winner. Thanks.
Watch out or you'll get sued.
Post Posted: Wed Sep 21, 2011 10:59 am
yes im a simpleton.
jeoltarded pompoms
Post Posted: Wed Sep 21, 2011 11:01 am
resetting leaves aint cheap though... locally here its about $110 a pack from memory. i looked into it myself a while back. once set no one will guarantee it wont just sag anyway cos of the modified arch.
Vehicle: Ducati Monster
Post Posted: Wed Sep 21, 2011 11:04 am
who said doing anything properly is cheap?
Post Posted: Wed Sep 21, 2011 11:09 am
Its going the other way
$110 a leaf is pretty good, its a fair shit of a job even for us that can fix our own junk
Vehicle: 2018 DMAX
Post Posted: Wed Sep 21, 2011 11:16 am
I was quoted $300 to reset four packs from a place in Townsville a few years ago... Probably gone up in price.
Id personally swap a leaf or two out for similar length thinner leaves.. What ever you do will eventually sag if you drive it..
Or reset the packs yourself if you have appropriate tools..
Post Posted: Wed Sep 21, 2011 11:47 am
seeing as there is a bit of tech happening is it possible to make springs stiffer with out adding lift?
Vehicle: 2018 DMAX
Post Posted: Wed Sep 21, 2011 11:53 am
shep, I had some mains and load leafs made for the back of mine. They were based on EFS rears but made thicker and a tiny bit longer. Gives me the height and they seem to work well, even though there quite stiff.
Post Posted: Wed Sep 21, 2011 11:59 am
i already have long springs and they used to carry a load well however i have done to
many trips like this and they dont carry a load very well anymore.
Post Posted: Wed Sep 21, 2011 12:57 pm
stiffer = thicker... you'll need to have them custom made. its do-able though. i was looking at getting a hilux pack made for the rear of mine using thinner steel so it would flex better - but once i got the price on doing so i was a lot less motivated.
Post Posted: Wed Sep 21, 2011 1:03 pm
Shep, if you want any springs made try this mob, they've been in the game that long & have a wealth of knowledge.
http://www.industrialsprings.com.au/index.htm
http://www.industrialsprings.com.au/leafm1.htm
they make a custom leaf for nissan australia to fix the dragging bum that the tradie utes get from being loaded all the time, manufactured by industrial springs & fitted by nissan all around aus.
Post Posted: Wed Sep 21, 2011 2:14 pm
:helloo: stockman
I've found some inspiration for your build!
This link is good as well: http://www.layitlow.com/forums/16-post- ... em-up.html
I want my old sig back :(
Post Posted: Wed Sep 21, 2011 2:18 pm
Alien, This is tech not so cal mexican bling.
Know anyone with a bench press?
Mark out the leafs at 50mm intervals, and eventually bend them with a few pumps at each interval, time consuming, but it works. Its how i reset my rear mixed corolla springs to all match and give me a bit of lift.
OR, Reset the main and second, then run the stock original suz pack underneath.
Mixing flat springs with lifted doesnt work, it will bend the top springs into quarters. Or this will happen: See pic 1
The main spring must always be fully supported by the second for a 4wd. Or this will happen: See pic 2
Flat Corolla spring + 2" bottoms
Post Posted: Wed Sep 21, 2011 7:46 pm
yes im a simpleton.
jeoltarded pompoms
:lol: :goodjob: well played. hahahaahahh
Sj70 tintop
Post Posted: Wed Sep 21, 2011 7:55 pm
Lol. It doesn't even seem like a made up word. :lol:
Vehicle: 4wd
Post Posted: Wed Sep 21, 2011 9:05 pm
Ben_Sierra wrote:
:helloo: stockman
Now that's a great idea. I could bag it.
I could go one step gayer and use a oxygen tank as air supply.
Post Posted: Wed Sep 21, 2011 10:29 pm
oi dont blame me, it was ben!
Post Posted: Wed Sep 21, 2011 10:37 pm
extra or longer leaves will make it stiffer, with teh same amount of free arch it will settle less once loaded (IE in teh car wheels on teh ground) so may be higher but probably not a lot
another option is a load leaf that isnt in contact with the main pack till the extra weight drops the back some
Post Posted: Wed Sep 21, 2011 10:49 pm
Shep, do some fab work, get a set of torana front coils, and set them between the axle and the chassis.
Dunno about nowdays, but in the 80s when I was living there, near all the tojos had this, helped ride and load, mostly ride, but in the case of the light zook, load mainly id say.
Post Posted: Wed Sep 21, 2011 11:44 pm
Really?
Lil Foot!
Post Posted: Thu Sep 22, 2011 12:58 am
Really?
Longer as in pull a leaf out that is 3/4 the length of the main and replace it with one the full length, not chuck a pack in so long you need to hook it to a trailer
Users browsing this forum: No registered users and 210 guests
