It is currently Tue Sep 22, 2026 9:10 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue Sep 13, 2011 12:26 pm
:D I'm going to make me a code finder thingyo now :D !!!
Vehicle: 2001 Jimny M13A
Post Posted: Tue Sep 13, 2011 12:32 pm
When your finished with it; store it in your glove box....
Post Posted: Wed Sep 14, 2011 8:18 am
i Can't find that fuking wire :? . But the light has gone off now any ways :lol: .
Post Posted: Wed Sep 14, 2011 8:19 am
it's a plug silly :crazy:
Post Posted: Wed Sep 14, 2011 8:20 am
:oops: I meant plug :lol: . Will this 'plug' be plugged into any thing? :roll:
Post Posted: Wed Sep 14, 2011 8:22 am
nope, it will be loose.
Post Posted: Wed Sep 14, 2011 8:25 am
Moag wrote:
Don't fuck with the yellow one!!!
I can't stress this enough!!!!
Yellow harness or plug, DON'T FRUCK WITH
Post Posted: Wed Sep 14, 2011 9:08 am
Fucking with the yellow stuff results in ....... DEATH!!!!
Post Posted: Wed Sep 14, 2011 10:07 am
whats it do steaky? something to do with airbags?
Post Posted: Fri Sep 30, 2011 4:50 am
Lately my Jimny has been idleing like crap and the check engine light comes on.
Also I remember the other week I disconnect to battery to get some wires through the fire wall.
So I'm guessing I cleared all my codes, how do I get them back?
Post Posted: Fri Sep 30, 2011 7:37 am
Get the code and post it :hello:
If it still has a problem, it will come back.
Its OK to leave the little bridge wire in and keep driving around for a week .. . .. . .. . .. . .. . .. . .. .. means its got no simple codes.
Removing the Dome light fuse will clear your codes to, from memory. :wink:
Post Posted: Thu Nov 10, 2011 8:52 am
Hey guys, my 02` jimny isnt starting, i read thru this thread, found the engine light code trick and got it to work, it came up with 23, (two flashes followed by three flashes) is this the air temp sensor?
Post Posted: Thu Nov 10, 2011 8:57 am
shouldn't stop it from starting.... :?
Post Posted: Thu Nov 10, 2011 9:00 am
From experience it will run without it
Post Posted: Thu Nov 10, 2011 9:06 am
damn, just tried it again while trying to turn the motor over and the same code again, tho i did hear a quick burst of clicks.....any ideas, the burst of clicks only happen once / turn of the key, drove it home this arvo fine, hour later it wouldnt start :S
Post Posted: Thu Nov 10, 2011 9:10 am
is it a M13??
does it sound to be winding over quicker that normal??
Post Posted: Thu Nov 10, 2011 9:16 am
from my limited understanding its an M13A - 2002 JX jimny........
i should have mentioned the starter motor isnt even turning :( this is the obvious problem but i was wondering about other problems
thanks for the quick replies btw
Post Posted: Thu Nov 10, 2011 9:26 am
with the click's, did the dash light's flicker at the same time???
Sound's like you have a dead battery mate....
Post Posted: Thu Nov 10, 2011 9:35 am
no flickering, i have tried jump starting it also
checked all the fuses and they are fine, radio turns on, head lights turn on
Post Posted: Thu Nov 10, 2011 9:39 am
Do you know what the starter look's like??
You could try tapping it & hitting the key at the same time ( 2 people make this easier.)
Post Posted: Thu Nov 10, 2011 10:12 am
well im giving up for the night, cant find anything loose or broken :S
Post Posted: Thu Nov 10, 2011 7:37 pm
clicking sounds like not enough battery power to throw the starter motor solenoid, when you say jump starting do you mean roll the car and pop the clutch while in gear, or do you mean connect another car's battery to yours?
Post Posted: Thu Nov 10, 2011 8:13 pm
Ive tried connecting another car for 10 min while it was running to see if that helped - it didnt, i managed to push start it down a small hill this morning, any thoughts?
Post Posted: Thu Nov 10, 2011 9:07 pm
Once started does it run properly? Have you tried starting again after a good run?
Post Posted: Thu Nov 10, 2011 9:08 pm
yep ran fine, didnt start again once i turned it off :(
Post Posted: Thu Nov 10, 2011 9:10 pm
My guess is also a stuffed battery :wink:
Post Posted: Thu Nov 10, 2011 9:16 pm
would it not be the starter motor? the battery seems to be able to handle aircon, radio and lights while running, also wouldnt it have started when i used the jumper leads to another car?
dont get me wrong, it would be great if it was just the battery....
Post Posted: Thu Nov 10, 2011 9:21 pm
Stop by an auto electrician, he'll test the voltage and then you know.
It could be mud and crap in the starter but 90% it'll be the battery. Starter cranking takes a lot of battery power, A/C etc not so much.
I had a similar issue as to what your describing....replaced the battery...never been a issue sense! Can you take your battery some where to get tested?
Post Posted: Thu Nov 10, 2011 9:22 pm
Beat you!
Users browsing this forum: No registered users and 181 guests
