It is currently Mon Aug 03, 2026 1:33 am
Post Posted: Fri Oct 07, 2011 7:51 am
:helloo: Gang,
I have been looking at getting some new radius arms for the front and rear. For the front i will either be getting jimny bit's 4" radius arms (once released) or ORA 4.5" arms. But for the rear i come across these
http://www.alibaba.com/member/tw1022821 ... _Style.jpg
They are a 2peace arm i would think they would help the rear end flex right?Also help stop some of my binding issues to? But the thing putting me of these arms ATM is i'm not to sure how they would handle on road? :?
Any one know how these arms would go on road? I would really like to know...
Cheers,
Post Posted: Fri Oct 07, 2011 8:01 am
wont make any difference, even with a joint there its still a triangle and as everyone that went to primary school knows triangles are pretty strong and dont move
if the short link was adjustable it could be used to correct castor though
Post Posted: Fri Oct 07, 2011 8:04 am
:? Could you see any other reason for them been a 2 peace arm then Royce?
Post Posted: Fri Oct 07, 2011 8:05 am
To look fully sick and fool people that dont think that they are hardcore?
Post Posted: Fri Oct 07, 2011 8:06 am
Wouldn't of brought a jimny if i wanted that :roll:
Post Posted: Fri Oct 07, 2011 8:16 am
Y not just spend the money and get some one to flip the factory arms ontop of the diff
That way u end up with the arms flat again which will Handle and flex heaps better
U could put a johny joint in the chassis end which should help stop the arms from bending when flexed but wont stop the bind at the diff end .
Post Posted: Fri Oct 07, 2011 8:26 am
pretty jimny arms are made recycled sigma's & camira's...
Post Posted: Fri Oct 07, 2011 8:30 am
If there any think like coily arms the biggest problem is people not running soft rubber bushes in them .
Plastic bushes have no place in a radius arm because the arm bends before the bush does
Post Posted: Fri Oct 07, 2011 8:41 am
I'm running the factory rubber bushes in the rear...and it's binding at the chassis end first....(will double check that on the week end)
Post Posted: Fri Oct 07, 2011 8:48 am
I could make axle stand's out of them!!! :P
Post Posted: Fri Oct 07, 2011 8:53 am
That's what my coily used to do that's y I think Johnny joints at the chassis end would help a bit
Mine bent a rear arm from twisting it so much
Post Posted: Fri Oct 07, 2011 8:56 am
This!!! It has already started to twist :?
Gwagonsteve think's another solution could be to drilled the hole at the chassis mount 10mm lower so the arm has nothing to bind on....
Post Posted: Fri Oct 07, 2011 12:13 pm
just keep driving it put a locker in and it will componsate for the extra 3mm of travel your gonna get
dodgy brothers mechanical
Post Posted: Fri Oct 07, 2011 12:17 pm
The diff mounts break before the arms do, I've broken mine 3 times now... :lol: :x
helloo
Post Posted: Fri Oct 07, 2011 12:19 pm
I don't how people can compare a locker to having extra suspension flex, they are two very different things. Depending on the situation lack of either of them can cause sticky situations.
helloo
Post Posted: Fri Oct 07, 2011 4:50 pm
monkey wrote:
:helloo: Gang,
Cheers,
if u re gonna buy the ORA ones, u re better off buying the whole kit having the rear too... keeping it all under the same design/company
plus, why do you want more flex? u already have heaps... u want more flex start designing a custom new suspension system
Post Posted: Fri Oct 07, 2011 8:53 pm
Monkey, I can see how the extra bush in the arm you are looking at will offer 1 more bush to flex but this been the only benefit, might be all you need.
http://item.rakuten.co.jp/hb-1st/877761/
have you considered this 4 link setup for the rear?
rubber bushes are a must in Jimny suspension it needs the flex and why caster bushes are not worth their weight in the performance benefits.
Post Posted: Fri Oct 07, 2011 10:02 pm
8) it looks to be a bolt on kit right? Might have to look into getting that kit....
Post Posted: Fri Oct 07, 2011 10:51 pm
cause u can have as much suspension travel as u like but with an open center diff as soon as a bit of weight comes off the ground the wheel is gonna start spinning
but lockers and reasonble flex is ample
might have to designe some new front shocks eh monkey
they dont seem to be long enough
Post Posted: Sat Oct 08, 2011 12:11 am
Jimnybits Arms FTW!
MY BUILD THREAD HERE!!!!!
Post Posted: Sat Oct 08, 2011 12:26 am
4link :D i am doing something differnt with mine.
Post Posted: Sat Oct 08, 2011 7:18 am
COOL!
Post Posted: Sat Oct 08, 2011 9:25 am
hold on........
what about this one
Post Posted: Sat Oct 08, 2011 10:24 am
gman wrote:
hold on........
what about this one
Saw that on their site too. Pretty cool. Definitely would like to see pics installed
Post Posted: Sat Oct 08, 2011 10:33 am
Did you learn that riding a quad :roll:
Post Posted: Sat Oct 08, 2011 10:43 am
locked rear on my quad, goes most places for shore
heaps of travel is good but still gotta keep the wheels turning as andrew learnt today
Post Posted: Sat Oct 08, 2011 11:53 am
what happened today?? =)
Post Posted: Sat Oct 08, 2011 7:29 pm
X2
Post Posted: Sat Oct 08, 2011 9:34 pm
gman wrote:
hold on........
what about this one
8O I could glue that into Sully's bum!!!! 8O
Post Posted: Sat Oct 08, 2011 11:31 pm
nothing to his car, just a quick powerlines trip to test some things
Users browsing this forum: No registered users and 260 guests
