It is currently Thu Oct 15, 2026 3:16 am
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Oct 09, 2011 8:29 am
I got a throttle body i'll eventually pop on top of my LPG setup, just wondering what this bypass bit is all about. Is this an idle flow bypass or is it a feed to go to some sensor? Hopefully the green arrows are dark enough to make sense of :oops:
Post Posted: Sun Oct 09, 2011 8:32 am
yes
That would go to the idle up air bypass solenoid. Block it off when you mount it. SHouldn't have any issues
Lil Foot!
Post Posted: Sun Oct 09, 2011 8:38 am
OK cool, I have the adaptor plate made, was just wondering if I need to get the dremel out and accomodate for this.
So the throttle butterfly is supposed to sit slightly open at rest to allow for an idle flow?
Post Posted: Sun Oct 09, 2011 8:39 am
yes.... :D
Post Posted: Sun Oct 09, 2011 8:41 am
If it has the bypass blocked off then yes it will need to be slightly open. Fab up a throttle stop so you can adjust your idle speed.
Lil Foot!
Post Posted: Sun Oct 09, 2011 8:42 am
It's got an adjuster screw already, but as it's set the butterfly is 100% closed at rest. Easy fix, cheers guys 8)
Post Posted: Sun Oct 09, 2011 6:31 pm
butterfly should sit slightly open so it doesnt jam or give a stiff feel when opening
Users browsing this forum: No registered users and 1014 guests
