It is currently Sat Oct 31, 2026 7:00 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Jul 07, 2011 9:52 am
Hey guys,
Thinking of making an auxiliary fuel tank for my jimny and slot it in-between my tow bar, where the muffler currently sits, once my exhaust is re-routed.
Just wondering what you all think and any feedback regarding possible problems etc.
I roughly measured out and will get close to 30L I think if I can make it to the size I want.
Cheers, Tim
Online
Post Posted: Thu Jul 07, 2011 9:54 am
Have you worked out how to transfer fuel between the tanks?
Steve
Not being a smartarse, just curious on how you are planning to do this.
Post Posted: Thu Jul 07, 2011 10:00 am
Steve
Yeah that's something I'm still thinking of, a few mates are mechanics and I was going to pick their brain on either a fuel pump on a switch or maybe if it's possible, wiring a fuel pump to the existing one to pump fuel in as it's burned.? Anyone with ideas on this? I just don't want to carry jerrys lol
Vehicle: 2011 Jimny
Post Posted: Thu Jul 07, 2011 10:07 am
we have a few cars at work (not SUZUKI) that are set up on a switch.
Essentially set up as two separate fuel tanks 2 fill points, one each side of the car 2 fuel pumps and separate lines up to a solenoid then one line from their on
Ill chase up some better info if you would like so that im not "bum steering" you
Jimny's really do ROCK
Post Posted: Thu Jul 07, 2011 10:10 am
Much appreciated :)
Post Posted: Thu Jul 07, 2011 10:16 am
use one of these:
its a pollak 6 port fuel valve and it will set you back about $150. I've brought one for my sierra, haven't installed it yet though.
Post Posted: Thu Jul 07, 2011 10:21 am
mrw82 wrote:
use one of these:
Ooooooooooo 8)
Post Posted: Thu Jul 07, 2011 10:54 am
what about venting the main tank to the pick up (bottom) of aux and than vent aux to the charcoal canister.
the fuel will be drawn from the aux tank as a vacuum is created from the main fuel tank level dropping
Post Posted: Thu Jul 07, 2011 11:10 am
I would assume that means there is no vent on either tank to make the vacuum? Would this make it non ADR compliant?
Post Posted: Thu Jul 07, 2011 12:01 pm
Both tanks would vent from charcoal canister main tank would draw fuel from aux before emptying than drawing air from aux via charcoal this was how longranger tanks worked on early 40 series land cruisers, also on rally bikes with rear tanks (Dakar etc) just an idea
If you had no vent on a fuel tank the engine would stop before the tank ran out of fuel.
no
Post Posted: Thu Jul 07, 2011 11:47 pm
if both tanks are at the same level, (top and bottom)
with the breathers both linked together,
and a decent internal diameter fuel line-fitted low down on both tanks, (I have seen the sediment drain in the bottom of the tanks used)
they will naturally transfer between both tanks- while needing only one fill point
only disadvantage is you need to allow time for fuel to transfer tank to tank while refuelling- thats why you use large diameter fuel hose.
I did this years ago with a V6 capri and it worked well.
if using sediment drain points on the tanks, just fit a decent water seperator type fuel filter
or you can do like Mahindra did with thier CJ3B jeeps twin tanks, simple fuel transfer pump from secondary tank to primary tank.
but this needs 2 fill points.
stephen.
Post Posted: Fri Jul 08, 2011 2:30 am
stephen.
Any pics by chance on the Capri?
How large a diameter would you recommend?
Post Posted: Fri Jul 08, 2011 2:32 am
no
I like this idea alot... Sounds easier than having two fill points and a pump.
Post Posted: Fri Jul 08, 2011 11:38 am
The V6 capri came with a 60 litre tank, 4 cyl. capri's had a 40 litre tank, I mounted a 40 litre tank behind my 60 litre, linked with (IIRC) 3/4 or possibly 1" hose, through fittings a mate of mine silver soldered onto the tanks (out of vehicle, washed out, and filled with water while soldering)
Breathers back then just vented to atmosphere and expansion hose overflowed onto the ground, I hung a charcoal canister to try and kill the smell of petrol. When filling- I just waited for the nozzle to click off, then checked my oil etc, by then it was ready to top off the tanks.
There wasnt much room in the boot for the spare tyre!
I will try and find photos of the old girl, unfortunately she has gone to the great wrecking yard in the sky( actually her remains are rusting away in country western australia.)
Post Posted: Fri Jul 08, 2011 11:42 am
I should really get my long range tank finished :oops: :roll:
Post Posted: Fri Jul 08, 2011 11:40 pm
Yeah that'd be sweet man... Cheers!
Post Posted: Thu Sep 22, 2011 12:40 am
any progress here? Any one know where the long range tank that I think robsjimny from jimnyworld had made up in the 6 or 7 years ago someone should have it copied
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Sep 22, 2011 2:12 am
I have been in contact with Outdoor Auto in Brisbane and this guy is working on a Jimny tank at the moment. It is not ready quite yet but I believe he is fitting his first one this week. I am not sure what process he uses for transferring fuel. It sits where the muffler currently is between the tow bar and the existing fuel tank.
Since I am going to do an exhaust upgrade soon I would like to know where you put the muffler and what muffler you used please Tim. Did you keep the resonator as well and how did it turn out for noise in the cabin?
Thanks
Mike
Post Posted: Thu Sep 22, 2011 3:34 am
If it's from Outdoor Auto then expect to pay lots for it....and some people think ARB pricing is bad.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Sep 22, 2011 8:33 am
Thanks
Mike
I didn't end up doing it yet, one guy said it would be too loud, however the 2 inch hardly makes a noise in the cabin, only a low warble sound.
The guy that was going to originally do it said he would put a small muffler under the passenger side on the inside of the chassis rail, and bring it out at the rear passenger side.
I'd definitely be interested in an ODA one... Most of the reason for not doing it is cause I couldn't be sears making the tank and figuring out how to pump it lol
Post Posted: Thu Sep 22, 2011 9:18 am
I spoke to ODA last week and he mentioned around $1,000 for the tank but I don't know what that will include. This is good compared to what the Longranger quoted me. I did read I think on this site that moving the muffler forward would significantly increase the cabin noise. It was in the the Jimny exhaust thread.
Post Posted: Thu Sep 22, 2011 10:10 am
I could put up with the noise I reckon... Let me know when you hear more... $1000 is reasonable I reckon
Post Posted: Thu Sep 22, 2011 10:53 am
I will get in contact with the firm who started mine next week. There is sweet FA left to be done on the tank...but every time i call to book it in, they never call me back :?
Post Posted: Tue Sep 27, 2011 10:16 pm
Hey Monkey, Any news on this ??
Here you go Atari, stick that in your mangina
Post Posted: Tue Oct 11, 2011 5:20 am
:helloo:
Post Posted: Tue Oct 11, 2011 9:08 am
jimny_timmy wrote:
:helloo:
:helloo: bit poor atm with all the new shit happening on the jimny....so i dont really care about the long range tank ATM :helloo:
Post Posted: Wed Oct 19, 2011 4:58 am
:thefinger:
Zook is going in some time next month to get the tank done :wink:
Post Posted: Wed Oct 19, 2011 6:32 am
monkey wrote:
:thefinger:
8O :D :helloo:
Post Posted: Wed Oct 19, 2011 11:34 pm
An update on the ODA tank. I called Tim last week and he does not have it ready yet but his price is now $1,800 so it is off my agenda. Back to two Jerry cans at that price.
Post Posted: Wed Oct 19, 2011 11:43 pm
I wonder if there getting the tank from the mob that's doing mine....
Users browsing this forum: Google [Bot] and 368 guests
