It is currently Wed Sep 23, 2026 3:29 am
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Oct 21, 2011 10:35 pm
The rear of my car sit about two - three inches higher than the front end, and it looks a bit strange with all this space under the rear guards and my little 215s. The suspension has been lifted already (by the previous owner I guess), and while the front is good - the back is a bit overkill. I'm sure the clearance would be handy running big ol' muddies, but I can't see myself going this route any time soon.
What are my options to level it out a bit? I have 5-pack King springs in the back, and a shackle link approx 3" from hole to hole. Being a noob i'm not sure if you can eliminate the shackle (seems like a 'must have' so the spings can flex a bit), but if I did I reckon it'd sit about right. If there's an easy fix i'll do it, but if it's likely to cost a bunch i'll leave it be.
Post Posted: Fri Oct 21, 2011 10:39 pm
Take a few springs out of the leaf packs. You could do it home yourself.
helloo
Post Posted: Fri Oct 21, 2011 10:51 pm
Can you get a pic of how front and back leaves sit? Like a pic of the actual leaves?
Sounds like you may have a 2" lift in the back only.
Post Posted: Fri Oct 21, 2011 11:13 pm
I'll take some pics when the rain decides to bugger off. You could be right BlueSuzy - that might explain a few things.
Any drawbacks or consequences if I take out a couple of springs in the pack?
Post Posted: Fri Oct 21, 2011 11:45 pm
could also be heavy duty leaves in the rear (for carrying a load). when i had my 2" spring in my sierra i had about 1" more in the back than the front, didnt look out of place though.
Vehicle: 02 jimny
Post Posted: Sat Oct 22, 2011 12:02 am
Couple fat mates you'll be right. do you pull a trailer at all if not i don't see a point for hd springs. remove leafs just leave 3 leafs
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Sat Oct 22, 2011 12:38 am
Removing leaves allows the axle to 'wrap' more. What are these shackles you have? Do you have the same on the front?
Post Posted: Sat Oct 22, 2011 2:36 am
Can't find my bloody camera to get pics. Shackles are the same on both ends of the car though.
Here's an old photo from my Rigs thread, can't see everything but it's the best I could find:
Here's how it high sits with 215s, not the most recent pic but the best side-on I could find:
Post Posted: Sat Oct 22, 2011 2:58 am
thats exactly how mine sat... but you've got the extra weight of the tin top so it should sit a touch lower.
the 2nd leaf up is the one you'll want to take out... the very bottom one isnt really neccessary either.
Post Posted: Sat Oct 22, 2011 3:01 am
pick up a fattie & chuck her in the back, they need some loving too. :lol:
Post Posted: Sat Oct 22, 2011 3:05 am
I'd start by just pulling out the load leaf (smallest one at the bottom) and see if it settles down a bit
Post Posted: Sat Oct 22, 2011 3:38 am
the flat load leaf wont lower it cause its not doing anything yet
next one up will though, its good for about half an inch
Post Posted: Sat Oct 22, 2011 3:51 am
when i took my load bearing out it got higher ... until it began to sag
Post Posted: Sat Oct 22, 2011 3:55 am
it would have gotten higher by the thickness of the leaf, cos as you take leaves out you shorten the distance between the leaf pack and the diff housing. its like the reverse of lowering blocks:
edit: wait that only works on the main leaf... nevermind.
Post Posted: Sat Oct 22, 2011 4:09 am
yeah this is true alien but it actually got higher then the distance of the leaf.I think removing the load beairng increased the arc, they were some stiff as shit wierd riding springs which is disliked emmensly.
Post Posted: Sat Oct 22, 2011 4:14 am
Keep you warm.. And you know some food wont be too far away either!
Vehicle: LJ80
Post Posted: Sat Oct 22, 2011 5:38 am
i would take out the second from the bottom
although ive just put mine back in
hit the bump stops too often on the quality roads around here.
Post Posted: Sat Oct 22, 2011 5:58 am
Taking out the load leaf will make the others work more, this may help it to settle down some
Post Posted: Sat Oct 22, 2011 6:13 am
How? Load leaf only comes into contact once the vehicle is loaded and sitting 'low'. At the mo its a good 2-3inch away from even touching the load bearer.
Che, start by removing the lowest curved leaf as that is adding to your static spring rate and height.
Dan
Lil Foot!
Post Posted: Sat Oct 22, 2011 6:24 am
You're just thinking static JrZook. Not denying that the next one up won't make a difference, I just know with mine I destroyed 3-4 pairs of rear shocks from axle wrap after I removed the load and next one up. Just removing the load leaves may not do much straight away but after a while it may help the others flatten out a bit
Post Posted: Sat Oct 22, 2011 9:40 am
Correct! I thought we were talking static as the rear sits higher than the front "as it sits". Many peps on kings are running only the top 3 leafs with no issues at all. Stekky is a good example and his gets used.
Lil Foot!
Users browsing this forum: Google [Bot] and 219 guests
