It is currently Wed Nov 04, 2026 12:15 am
Post Posted: Wed Nov 09, 2011 9:13 pm
Hey guys, what should I expect when doing this? Are the bearings hard to get off? I have a bearing puller will that do the job?
Post Posted: Wed Nov 09, 2011 9:18 pm
Ya need a press. Or a grinder and a hammer. I always just use a grinder then a cold chisel and hammer.
Post Posted: Wed Nov 09, 2011 9:46 pm
What exactly do you grind, As much of the bearing as you can with out hitting the axle?
Post Posted: Wed Nov 09, 2011 9:47 pm
You need to grind the bearing and the collar. They will probably get hot enough that they will just slide off anyway.
Post Posted: Wed Nov 09, 2011 9:49 pm
Grind as much as u can then use a cold chisel nd hit inside the crack of the sleeve. Thee sleeve should eventually crack and slide off. Bearing is a bit harder as you can't really get ion there witth a grinder.
Another hint make sure you put the backing plate on first before you press on the new bearings ;)
Post Posted: Wed Nov 09, 2011 9:53 pm
Are they hard to press back on?
Thanks for the help!
Post Posted: Wed Nov 09, 2011 9:54 pm
http://auszookers.com/index.php?name=Ne ... cle&sid=17
Post Posted: Wed Nov 09, 2011 9:57 pm
http://auszookers.com/index.php?name=News&file=article&sid=17
i looked hard for a thread!
Obviously didnt look hard enough :lol:
Users browsing this forum: No registered users and 65 guests
