I do need to update that though. In the US all 16V models had a MAF (Mass Airflow Meter), in many other countries the earlier models have a VAF (Volume Airflow Meter). The VAF models give code 34 for both signal high and signal low and its a voltage limit rather than a current limit. The MAF is usually a 56B80 and the VAF a 56B70.
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
Posted: Thu Nov 24, 2011 10:25 am
steak_knife wrote:
Hay Mr Rhinoman!!!!! Do you know the resistance to change the map's in the G13bb ecu's????
Its not usually quite as simple as that because the temperature sensors are very non-linear. On some models the maps themselves can be changed, it really depends on what type of ECU you have.
Users browsing this forum: Google [Bot], phlix, Suortin and 236 guests
