It is currently Sat Oct 10, 2026 6:19 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
Post Posted: Thu Nov 24, 2011 4:33 am
Ben_Sierra wrote:
Error code 34?
What my guess was. Just hoping I was correct.
Any idea if this is a repairable fault. I have cleaned it.
Maybe she has had it?
Post Posted: Thu Nov 24, 2011 8:29 am
I have a comprehensive list of fault codes here:
http://www.rhinopower.org/diag/cel.html
I do need to update that though. In the US all 16V models had a MAF (Mass Airflow Meter), in many other countries the earlier models have a VAF (Volume Airflow Meter). The VAF models give code 34 for both signal high and signal low and its a voltage limit rather than a current limit. The MAF is usually a 56B80 and the VAF a 56B70.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Thu Nov 24, 2011 9:15 am
Hay Mr Rhinoman!!!!!
Do you know the resistance to change the map's in the G13bb ecu's????
:P
Post Posted: Thu Nov 24, 2011 10:25 am
:P
Its not usually quite as simple as that because the temperature sensors are very non-linear. On some models the maps themselves can be changed, it really depends on what type of ECU you have.
1986 Suzuki SJ413K
Users browsing this forum: Google [Bot], phlix, Suortin and 231 guests
