It is currently Fri Oct 02, 2026 3:14 am
Vehicle: 2" lift, 215 a/t
Post Posted: Mon Nov 28, 2011 9:37 am
Hey all I've got an 06 Jimny without the factory roof rails. I was wondering if there is any that mount straight to the sides of the roof or must I find some factory rails?
Thanks!
Post Posted: Mon Nov 28, 2011 9:48 am
You can get aftermarket roof racks for your Jim. Unsure brand though.
Original Jimny roofracks are held on by studs welded through the original body from factory. So possible to do, but it will be very messy and time consuming.
Post Posted: Mon Nov 28, 2011 9:54 am
So the aftermarket ones fix to the roof or the rails?
2" lovells lift, snorkel, 215/75/15 A/T's
Post Posted: Mon Nov 28, 2011 9:59 am
spanish company - not sure if you can get them though
cruz
:wink:
Vehicle: 2001 Jimny M13A
Post Posted: Mon Nov 28, 2011 10:12 am
Something like these, Rhino Sportz, though you will need to drill some holes in your roof to pop rivet the rails on.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Mon Nov 28, 2011 10:32 am
some of the prorack ones clamp into the door recess might be able to work something out with them and one of the fitting kits
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Mon Nov 28, 2011 10:52 am
BAZZOOK's rails
Post Posted: Mon Nov 28, 2011 6:57 pm
Yeah might be easier to find stock roof rails from a wrecker and go from there. They should fix on straight away I suppose?
Post Posted: Mon Nov 28, 2011 7:03 pm
They are going to be a mess. Trust me. Get an aftermarket set.
Post Posted: Tue Nov 29, 2011 1:26 am
So you think find factory rails and then an aftermarket set of racks?
Post Posted: Tue Nov 29, 2011 1:30 am
Your not getting what i'm saying.
http://www.auszookers.com/index.php?nam ... roof+racks
You do not have these studs.
You will be better off running aftermarket racks ONLY
Ring 'Rhino' and other makes and see what they recomend?
Post Posted: Tue Nov 29, 2011 1:35 am
Rhino rack mate, they have 2 version, one for rails, one without.
the ones without have a track you have to pop rivet onto the bare roof, then the rhino rails go from left to right, and you can slide them to adjust fwd/back distance. much better than the stock ones IMO
PS EXACTLY like the red Jim a few posts up
MY BUILD THREAD HERE!!!!!
Post Posted: Tue Nov 29, 2011 3:09 am
Alright mate sorry didn't quite pick it up but understand now. Thanks for the help!
Post Posted: Tue Nov 29, 2011 3:10 am
No leakage problems doing it this way with pop rivets?
Post Posted: Tue Nov 29, 2011 4:31 am
I would use a good silicone, and paint the drilled holes before you put things together. Will keep the rust away.
Post Posted: Tue Nov 29, 2011 6:25 am
what he said.
i think the kit comes with a sort of tape that goes under the rail also. but yeah, paint and silicone is king.
Vehicle: 94 Vitara LWB G16b
Post Posted: Tue Nov 29, 2011 11:45 pm
I was told Silicone is water based, therefore will rust? Sikaflex is the better option I was told...
I will be doing mine soon.
94 Vitara LWB G16b
Post Posted: Tue Nov 29, 2011 11:55 pm
There may be some out there, But seem to be hard to search for.
I binged for "silicone water based" Keep coming up with lubricant for anal.
Found some tech on Sika
http://www.sika.com.au/cmc/Joint_Sealan ... esives.htm
So it really depends on the type/choice of silicone. Sika is a brand. Not a type.
Users browsing this forum: Google [Bot] and 145 guests
